Get a windows password recovery tool,which can easily bypass windows password if you just forgot windows password.
Boot computer and press Ctrl+Alt+Delete twice when you See Windowswelcome screen / login screen. It'll show classic login box. Now type"Administrator" (without quotes) in username field and leave passwordfield blank, press Enter and you should be able to login Windows and you can reset your account password from "Control Panel -> User Accounts".
If that doesn't work, I think you have to windows password recovery software, for example Windows Login Recovery.
For recovering Windows Password safely, I suggest product Windows Password Seeker. Not only support XP/Vista/2000/NT, but also compatible with windows 7, it works perfectly to recover Windows Password. I wrote it to a Usb stick. Booting up and clearing my password within 4 minutes. You could Google Windows Password Seeker or download it from: http://www.passwordseeker.com
I believe probably the easiest and safest way for you is remove your Windows OS Passwords with Windows Password Recovery tools. I found a good one at http://www.reset-windows-password.com last week, and then I downloaded it and used it to remove the lost password within only few minutes. Furthermore, the powerful tool didn't cause a little data lose. It's worth an attempt.
Can't remember your windows xp admin password?Windows password key 8.0 has a neat trick that will get you back in.This method is easy for everyone to follow.
Download the utilityand install it then burn the software to a CD/USB drive,then insert the newly created CD/USB drive to your locked pc and reboot your computer,then press "F2" to enter your BIOS setup,following the instruction to reset your lost windows password.
I usually used the cheapest and easy to use tools, especialy free trial: like Windows Password Recovery tool 3.0 to reset Windows XP password.
Or you can try hacker. O(∩_∩)O ~
Its difficult to recover the password but you can reset your password.
Just boot by safe mode(no need of password for safe mode) and there go to control panel and in the user account options remove the password for the account and create a new one. recovering a password is difficult and most of the softwares are not reliable
If you only had one"administrative" user account created and you've forgotten the password to it, try starting the computer in Safe Mode. Supposedly this will enable the built-in Administrator account for the one session. The default password may be a blank. Get into Safe Mode by repeatedly tapping the F8 key as the computer is starting up. If this works for you, then you can set a new password for your normal account.If this didn't word,then a password recovery utility is available for you,from gg ,i found this effective tool: Windows Password Unlocker
I hope this information was helpful…
Have a nice day
