Question about Garden
Will not start fitted new spark plug still will not start also cleaned air filter
  • 1,340 Answers
CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
New spark plug, fresh gas, clean air filter. Wont start.
take the fuel line off at the carburetor. if fuel is coming out then you have a plugged carburetor. take it off and apart. clean it really good with carburetor cleaner and put in a new needle and seat. it should run as good as new.
Apr 30, 2016 | Garden
Saw wont start, getting fuel and spark
Try starting it with the air filter removed. If it starts, clean the air filter. It could also be the fuel filter. If you replaced all the fuel lines, make sure you didn't get the oil line mixed up with a fuel line
Jan 25, 2015 | Poulan Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
Hard to started
Clean your battery connections, and water check earth connection from car body to the engine check PCV valve or hose for leaks tune up your engine =fit new spark plugs set ignition timing check the air filter or even change your fuel for while check fuel filter.
Sep 23, 2012 | 1999 Chevrolet Silverado 1500
My poulan saw will only run for 30 seconds and then quits. It ran for about 30 minutes before developing this problem. Plug is dry with tan color. Air filter is clean.
Try a few simple things first, clean the air filter, remove and replace the filter inside the fuel tank on the end of the fuel hose,check the fuel hose up to the carb for cracks and leaks, fit a new spark plug.
Jun 27, 2011 | Poulan 14" Chainsaw
Lost manual it has not been started in along time I need to know how to change spark plug ,clean carb. correct fuel mix and what ever else I need to do.
To change the spark plug, remove the top cylinder cover, take a 19mm box spanner ( a pretty standard chainsaw combi wrench ) turn the plug anti clockwise to remove, re fit clean or new plug, wash the air filter in soapy water and allow to air dry, if the saw has a primer bulb, fill the saw with fresh fuel and prime 15/20 times until the bulb is 3/4 full of fresh fuel, this will flush the carb through, so there should be no need to remove and clean the carb.
Apr 10, 2011 | McCulloch Garden
What parts do i needed for a tune up on a kia 2004 saoda
write down the manufacture date the vin number engine type and capacity eg1.5,1.8,2.0 armed with this info head down to your parts shop you will need. oil correct grade for your car 5litres will be more than enough or just right for 4 cyl. oil filter spark plugs some cars use irridium or platinum with some cars these do have standard equivilant that are cheeper fuel filter air filter a can of throttle body cleaner to clean the throttle body jack up the car sit it on stands never trust a jack remove the drain plug from the sump drain the oil into suitable dish or container and dispose of it responsibly replace the sump plug and tighten it firm locate and remove oil filter fit new filter spin it on then tighten by hand half a turn locate and change fuel filter dont forget to inspect filters for leaks when service is finished add new oil to correct level start engine run til oil light has gone out swich off recheck oil level remove spark plug leads mark them or do one at atime change spark plug put leads back on open air box remove old filter loosen clamp on air intake where it fits on to engine at throttle body move out of the way hold butterfly open and spray with cleaner to remove built up deposits a small bottle brush is good to get inside refit the air intake pipe and filter the cleaner will make the engine run a bit rough you may have to wind it a bit to start it it will clear itself after running for a short time be shaw to refit any plugs or connectors and pipes
Apr 06, 2011 | 2004 Kia Sedona
What does a major tune up for a 2004 chevy impala consist of? What should be done and needs to be done?
New spark plugs, oil and oil filter, transmission flush and fill, fuel filter, air filter, coolant flush and fill, clean throttle body plate and bore, clean the MAF sensor, replace any loose or cracked vacuum lines, PCV valve, new air filter, new battery.
99% of the time all you should ever need for a tune up is new spark plugs, and a clean air filter and throttle body. But since your inquiry indicated "major" I gave it more critical thought.
Feb 18, 2011 | Chevrolet Impala Cars & Trucks
Hard to start, new racher455
1) Check plug & gap if that doesn't work try new plug. 2) Try cleaning air filter 3) Clean out main jet 4) Test petrol filter inside tank if dirty fit new one 5) Take plug out & fit inside HT lead & put to head of engine & see if you can see a spark when you pull the cord
Jan 24, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
2 1/2 Briggs......doesn't run smoothly....surges at all speeds.
Hi, Check that you have the correct spark plug fitted or fit a new one as it sounds like your plug is getting hot then shorting out.
Sometimes the magnito can do this as well. but I would start with the plug.
Nov 26, 2008 | Garden
Garden Logo
465 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
