Question about ASUS P4S800D-X Motherboard
Stop;0*000000*7b(0*f896863c,0*0000034,0*00000000,0*00000000)my computer shows a stop error screen every time windows opens
  • ASUS Master
  • 11,800 Answers
INACCESSABLE_BOOT_DEVICE = there's something wrong with your hard disk - either its driver is missing or it's the wrong one or the MBR was corrupted.
Start by fixing the MBR by booting into the Windows XP recovery console and run the command “  fixboot ” followed by “ fixmbr ”.
After that boot in Safe Mode and install the latest driver for the chipset and SATA/RAID.
Posted on May 26, 2010
COMPUTER - BLUE SCREEN
what is the error of the blue screen showed? etc Stop :0X00000FE
Jun 08, 2012 | Dell Computers & Internet
Blue Screen windows 7 PC closes with a Blue Screen and Restarts
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
How to analyze blue screen errors The first thing to do to analyze a blue screen error is to check the meaning of the STOP error code. You need to stop Windows from rebooting when a STOP error is encountered. Once the blue screen of death is shown, you can check the meaning of the STOP error code. Together with the filename of the driver or module, this will give an indication of the error cause.
Another option to analyze the cause of the blue screen error is to look at the Windows system event log or to debug the memory dump (minidump) that Windows created when the error occurred. The event log can be viewed using the event viewer. Right-click Computer in the Start menu, and then select Manage. In the Computer Management window select Event Viewer. The information in the event log can be of great help to isolate the cause of the blue screen error.
Reading the minidump requires a bit more technical knowledge, but Microsoft has tools to read the minidump.
The most common cause of blue screen errors In reality, the most common cause of blue screen errors is a device driver problem. Outdated, incorrect or corrupt drivers can cause the system to encounter a STOP error, resulting in the BSOD.
So the easiest way to try and fix a blue screen error is to reinstall and update your system's device drivers. This will ensure that all driver bugs are fixed and that all hardware has the correct driver.
If you know which device caused the error, you can update or reinstall that driver first. The file name in the blue screen of death can help identify the driver. Look for a file with the .SYS extension and search for that file name.
If you do not have the drivers for all devices, or are not comfortable updating your PC's drivers manually, you can use a driver update tool to find, download and update all device drivers for you. Such tools will accurately identify your computer hardware, including any device causing an error, and automatically install the latest drivers for it.
In most cases updating or reinstalling drivers will solve your blue screen errors.
Other causes of blue screen errors However, if updating device drivers does not fix the blue screen error, there are a number of additional things to try:
  • Load the default BIOS values - resource conflicts and timing issues can be caused by incorrect BIOS settings.
  • Update the BIOS - especially after adding new hardware or installing a Windows service pack this can help fix issues.
  • Update Windows - missing updates, including service packs can be a source of stop errors.
  • Check your system - run a virus scan and spyware scan after updating your definition files.
  • Driver rollback - if you have recently updated a driver, you can use the driver rollback to revert back to the previous driver version.
List of STOP Errors Causing BSOD:
  • Stop 0×00000003 UNSYNCHRONIZED_ACCESS
  • Stop 0x0000000A IRQL_NOT_LESS_OR_EQUAL
  • Stop 0x0000001E KMODE_EXCEPTION_NOT_HANDLED
  • Stop 0×00000023 FAT_FILE_SYSTEM
  • Stop 0×00000024 NTFS_FILE_SYSTEM
  • Stop 0x0000002E DATA_BUS_ERROR
  • Stop 0x0000003F NO_MORE_SYSTEM_PTES
  • Stop 0×00000044 MULTIPLE_IRP_COMPLETE_REQUESTS
Here are 2 solutions:
Solution #1 Scan your registry for errors.
A Registry Cleaner scans your computer for errors in your PC's registry. Your computer's registry contains information about your Windows XP operating system, including driver, printer, software information. Over time, your computer's registry may start to contain obsolete data. A corrupt registry will easily slow down the speed of your computer because applications and drivers are loaded even though they're not in use. Fixing your registry of errors will not only prevent the Windows XP Blue Screen Of Death, it'll allow your computer to boot faster, open up multiple folders quicker. A listing of registry cleaners can be found here.
Solution #2 Process of Elimination
When the CPU calls certain functions from the RAM, or Random Access Memory, and the data rests in a faulty section of the RAM, this will cause the blue screen to appear. I recall a time whenever my computer booted up and started loading the Norton Anti Virus program, the blue screen error message would appear. This happens because the CPU is accessing data from faulty locations within the RAM when loading the anti virus software.
This method involves having 2 sticks of RAM. Remove 1 stick of RAM and wait to see if the blue screen surfaces, do the same for the other.
Through process of elimination, you'll find the cause of the Windows XP blue screen of death error.
Because getting into the hardware can be a little techy for computer hardware "adverse" readers, a simple 2 step plan is to first clear your PC of any registry errors. Then if the blue screen of death goes away, we would have saved ourselves the trouble of having to open up the PC casing and touching the hardware components
Dec 08, 2010 | Computers & Internet
Stop error screen
If you have installed a new hardware or software, it may be conflicting with the installed program there by causing your system to dump it time the conflict occurs. You have to boot the system to safe mode and uninstall the new software or remove the new hardware and restart the system. Your system is supposed the boot okay.
May 26, 2010 | ASUS P4S800D-X Motherboard
My computer opens but after some times blue screen with writings comes out saying: A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time...
it's a long shot but you can try to boot into the recovery console it you have the original operating disks press the letter "R" for repair and go onto the recovery console and trying a "fixboot" command at the command prompt. this has worked for me about 25% of the time
Apr 22, 2010 | Computers & Internet
Blue Screen Error Message
dear,
check it by changing Ram. its mostly happens b'coz of Ram.
regards,
Jul 27, 2008 | Dell Dimension 3000 PC Desktop
Startup problem
some other errore should come with this other wise try entering bios setup at boot then enable default setting. thyen restar yr system if it still continues, replace the ram and see. if that doesnt solve yr problem then u format yr system it should be ok.
May 24, 2008 | Dell Dimension E310 PC Desktop
Computer turns off and restarts again during the operation repeately.
Hi 2gerr, when you tested the board, was the board outside of the you're case?
Here is one suggestion you can try. Start the PC & press the F5 key every two seconds untill Windows Advanced Options Menu
is displayed on you're screen. You can not use you're mouse here. Use the up & down arrow keys & slide to, Disable automatic restart on system failure. Than press enter. What this should do for you is stop windows from restarting & give you time to catch what is causing windows to restart. If you receive a blue screen with an error message write it down. Press the pause key on the keyboard so you'll have time to write down the error message. It would not hurt to enter you're bios and turn off hault on all errors listed in the main menu of the bios.
Another could be the back side of the board could be touching the case. You can add a piece of a paper bag under the board.
Stopping a possible short. Lastly, enter you're bios & go the hardware monitor. Open hardware monitor & leave it there. Shut off you're monitor & walk away for about 10 minutes or so coming back from time to time & check the temp of you're CPU & mother board temp. Staying in the bios, let me know if the PC restarts.
Mike
Apr 25, 2008 | EliteGroup P4M800-M7 Motherboard
A Open Computer running Windows XP is
run with safe mode and go with admin privileges then when u are in go START -RUN - TYPE THERE ( MSCONFIG ) -startup and desable all startup items and restart the pc!!!
Let me know if u get help OK?
Oct 29, 2007 | Sony VAIO PCV-RS530G PC Desktop
ASUS P4S800D-X Motherboard Logo
289 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
