Question about Brother HL 2140 Laser Printer
My error light blinks on and off. I stopped my printer in the middle of a printing (I asked for too many copies), and pulled out the last sheet. Turned off printer and computer. Now I have this error problem and it won't print. Help! please.
    Scholar:
  • 94 Answers
Maybe you have a finding work to be print. Just check the printer status at the start menu. click the printer and faxes then double click the type of printer that you used. After that, the dialogue box appears then on the top of the box you see the word (Printer) click it and then click Cancel all Document then OK. That process are cancell all the finding document that you print before. If did not remove just switch Off the printer and turned it On again. Try this solution back in back if the finding document was not remove.
Posted on May 26, 2010
Cannon MP990 C610 error
Inkjet cartridges dry up very soon. You have to use it everyday. Or clear the nozzles using hot tap water soak. Or try new cartridges again.
Apr 03, 2012 | Computers & Internet
Everytime I start my printer I get a message to realign while there is NO problem with the alignment.
The printer alignment has to be completed as below,
  1. After printer prints the alignment sheet.
  2. Place the printed sheet on the scanner bed and press "start scan" or "start color copy".
  3. Wait untill the printer Power light stops blinking.
  4. Now turn off the printer and turn back on.
  5. Printer will not print alignment sheet.
Regards
Riztech
May 29, 2011 | HP PSC 2175 All-In-One InkJet Printer
Windows 7 home edition HP Deskjet D1660 Problem: Printer will print a full page document, but stops in the middle of printing a full page photo. I just installed this printer, i bought it yesterday....
I have the same problem with my printer. I don't use it too often, but when I attempt to print more than a few pages in succession, I run into this issue. Normally, the first few pages will print off just fine. Then, suddenly, it will print half of a page and simply stop in the middle. Pressing the power button gets the printer to release the stuck sheet of paper, but then it will not allow me to resume or delete what is in the print queue. I generally have to reboot my computer after unplugging the printer and plugging it back in before I can resume printing. It does this nearly every time with no known error messages. I don't understand why it happens.
Sep 04, 2010 | HP Office Equipment & Supplies
Canon MP145 Error 2
Just press the green (color) button about 5-10 seconds. Hope this help a bit.
Mar 25, 2010 | Canon Office Equipment & Supplies
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
Brother HL 2070N red paper light blinks but won't print.
Just fixed my printer issue, had the same problem, Would load 1 sheet, then jam, sometimes it won't pull the paper out of the tray, sometimes it would pull the paper to the toner area, but never into the toner, opening and slamming the paper tray while it attempted to load would usually work, but who wants to slam the tray 50 times? I was using Walgreens generic paper, 20lb, took some higher-quality 24lb HP paper and VOILA! It works every time! EVERYONE WHO IS HAVING THIS PROBLEM, CHECK THAT YOU ARE USING 24LB PAPER!!! Brother says 20-24 is acceptible, but sneaking one sheet of 20lb paper about 15 sheets down in a 20 sheet print job and it will stop at it every time, You can feel the difference, less like toilet paper and more like real paper.
24 LB PAPER! USE IT NOW AND THANK ME LATER!
Jun 27, 2008 | Brother HL-2070N Laser Printer
The top lights stays blinking and printer will not print
Yes definetly,
First cheak that paper was cuts wrincled from any side from top or bottom, after pulling if yes cheak that the
small part of papper jam in to the papper path or sensor earia
or papper feed out sensor actuater arm jam by pulling the papper by you after cheaking those things you will able to solve the problem you are facing,
vyas
Mar 23, 2008 | HP DeskJet 5550 InkJet Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Brother HL 2140 Laser Printer Logo
149 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
