Question about Electrolux Microwave Ovens
Does the electrolux ehd72100x induction hob come with mains cable
Does the electrolux ehd72100x induction hob come with a factory fitted cable to connect to the mains switch??
Aeg glass induction hob error code ER 21
reset the microwave. Disconnect the power cord, by 1minutes, and try again,the microcontroller is confuse.
If the problem persist you can be problem with the main controller board, repllace, but read your owner manual section troubleshooting for identi the error. download from www.retrevo.com
God bless you
Oct 27, 2013 | Microwave Ovens
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
Have no manual for my newly installed Electrolux Induction Cooktop
Hi judykeys,
Kindly specify the Model no. of the product to get a specific Manual..However plz try this link...Hope it works if not plz revert:
http://www.electroluxappliances.com/low/node51?aspxerrorpath=/low/kitchen-appliances/cooktops/induction/ew36cc55gs
Thanx
Aug 24, 2011 | Microwave Ovens
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
I have a Brandt induction cooktop and 2 hotplates don't work at all and the other 2 now don't appear to be connecting with the saucepan. Heat light starts to flash then turns off completely. Unable to...
Sounds like a wiring problem,take off of course with no power and check it out. No harm if no power,and replace wire and or componet with same.
Jan 11, 2011 | Brandt Microwave Ovens
Good morning We are about to fit a rangemaster classic hood 120cm approx. to suit our Elan 110 dual fuel cooker with a gas hob. What is the corrrect distance we should leave between the hob and...
In my experience, the hood should be just above head height, that will avoid banging your head, and at least 33 inches or 8ocm above the hob.
Hope this helps.
Nov 03, 2010 | Microwave Ovens
I live in spain I have purchased a zanussi hob ZVT64BV and it has 4 electrical wires blue, black, brown and green/yellow why is this and how do I wire it up?
That's a H05BB-F two-phase cable - http://www.icc.it/view_cable.php?id=30 - and it's not intended for you to wired it up by yourself. There is of course a way, but the circuit has to be assessed for viability by a qualified electrician beforehand. The reason there's a two phase connection is that the current to the induction coil COULD be too much for a normal cable.
If that's the case, your kitchen circuit would become a fire hazard - the fuses would not blow, the differential wouldn't trigger, but the cable in the wall and behind your other appliances and furniture might catch fire.
May 29, 2010 | Microwave Ovens
Microwave Ovens Logo
57 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
