I have a failed update in my update history list
  • 4,737 Answers
I am sorry, there's was an unexpected connection failure which i didn't notice. If your problem isn't solved yet, please let me know. I am ready to assist you further. Good luck.
Posted on May 26, 2010
  • 506 Answers
You can relunch the windows update and the failed update will try and run again. It depend on the version of your OS, but in windowns 7 click start, all programme, windows update then check update. This will check for the update that are not installed on your system and from here you can install the failed update. In Windows Xp, Click start Control Panel, Automatic Update and follow the instruction in theguide.
Why does window updates fail?
could be a bad update prior to the failure.Suggest going to programs and features and selecting show updates . Then remove two last updates and then try to update it again
May 02, 2017 | The Computers & Internet
Hi my mum has just purchased windows 8..can get onto facebook...but when she wants to play mindjolt games..(golf solitaire) it will come on... but then has a white screen where the game should be.altho it...
Hi there. Firstly... make your mom a cup of tea . You know how to calm her down . Then take on this task . It looks like a impossible task , but just follow the instructions . You can do this: Install the Windows 8.1 Update (KB 2919355)
  • ?Email
  • Microsoft support. Code 0x800F0922 This error might mean that a file needed by Windows Update is damaged or missing. Here are a few steps you can try to fix the problem:
    1. Run the Windows 8.1 Update troubleshooter to fix the problem.
    2. Install the Windows 8.1 Update or Windows RT 8.1 Update.
    Code 0x800F0923 This error might mean that a driver or other software on your PC isn't compatible with the update. For info about how to fix this problem, contact Microsoft support. Code 0x800F0922 This error might mean that your PC couldn't connect to the Windows Update servers. If you're using a VPN connection to connect to a work network, disconnect from the network and turn off the VPN software (if applicable) and then try to install the update again.
    The error could also mean there isn't enough free space in the System Reserved partition. You might be able to fix this problem by using third-party software to increase the size of the System Reserved partition. Error: We couldn't complete the updates. Undoing changes. Don't turn off your computer.
    Error: Failure configuring Windows Updates. Reverting changes. These are generic errors that might appear any time a Windows update fails. You'll need to determine the specific error code to investigate how to best resolve this problem
    You can find the error code for the failed update by viewing your update history. Look for KB 2919355 in the list, note the error code, and then contact Microsoft support.
    To view your update history:
    1. Open Windows Update by swiping in from the right edge of the screen (or, if you're using a mouse, pointing to the lower-right corner of the screen and moving the mouse pointer up), tapping or clicking Settings, tapping or clicking Change PC settings, and then tapping or clicking Update and recovery.
    2. Tap or click View your update history.
    Error: The update is not applicable to your computer. This error might mean that your PC doesn't have the required update KB 2919442 installed. Check to make sure that all important updates, including KB 2919442, are installed on your PC. If all updates are installed, you might need to refresh your PC.
    To refresh you PC:
    1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings. (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click Settings, and then click Change PC settings.)
    2. Tap or click Update and recovery, and then tap or click Recovery.
    3. Under Refresh your PC without affecting your files, tap or click Get started.
    4. Follow the instructions on the screen.
May 07, 2017 | Computers & Internet
Facebook keeps crashing
Follow these steps:
- Update Browsers
- Update Flash player
- Clear Cookies
- Clear History
- Fix registry errors
If problem still occurs then use system utility tool Reginout.
Jan 16, 2013 | Google Chrome
Need to know how to uninstall updates on windows 7
Hi
Please try the following steps to uninstall an update in
Windows 7
Click on Start >> type as follows in the search field
View update history
Open this program
you will find as follows
Review your update history
Check the Status column to ensure all important updates were successful. To remove an update, see Installed Updates.
Click on Installed update link
you will find the list of updates in this location
select the update and click on uninstall at the top
Regards
Chox
Nov 13, 2011 | Intel C++ Compiler For Windows 7.1 Full...
What are the factory default settings? What will I have to redo after the factory default settings are set?
Any customized setting you changed on the receiver will go back to factory default. Here is a list of the settings that would change:
  • Favorites Lists are cleared and the titles set back to List 1 - List 4
  • Search History is cleared
  • Alternate Audio is set to English
  • Closed Captions returns to default settings
  • Mode Reminder is enabled
  • Receiver is set to Dual User Mode
  • Caller ID history is cleared
  • Phone Setup is set to Touch Tone and No Prefix
  • Audio Output: Decoder set to Dolby Digital/PCM
  • Updates are set to 3:00 AM
  • Guide text is set to Small if the receiver is connected via HDMI and Medium otherwise
  • Guide format is set to Standard - Partial Guide with Video
  • Inactivity Standby is enabled
Locks, timers, DVR and Remote Address settings are not altered
Aug 19, 2011 | DISH Network ViP722 DTV Receiver /...
I am not able to install windows updates
go into Services, stop Automatic Updates and the BITS services. Then delete, then start them up. When you do this, the Update History log is destroyed. So the next time you try to look at your history log on Windows/Microsoft Update, it will come back empty until you install again. Then it will show from that point. If you have not installed all updates in the SoftwareDistribution/Downloads folder, these will have to be downloaded again.
You have two options:-
1. Delete the entire SoftwareDistribution tree and lose Update History (this should work but like I said you will lose download history)
However you could do this, but the corruption in the download file may remain
2. OR Delete the Downloads folder only, keeping the Update History data file (located in the DataStore folder), and take the chance that you don't get out-of-sync of downloaded files/not installed.
May 11, 2011 | Toshiba Computers & Internet
Xp pro sp1,2,3 installed. cannot install kb953297, kb974417, current windows live outdated, running outlook express cannot down load windows live replacement, office windows live, windows live essentials
You can ask Microsoft about these errors. There is no charge when asking for help with updates. When you open Microsoft Update and look at update history, click on the updates that failed and they often give you instructions on how to solve the problem.
Dec 22, 2009 | Microsoft Windows XP Professional
I cant intall update
if this is a failed microsoft update,write down the number or title,check add remove programs with the show updates box checked,if you see it installed then uninstall it an then check for new updates to see if it works,otherwise,go to microsoft update,view update history ,look for failed update ,click on it and follow the help links,usually end up at another update that needs to be installed first,just disableing microsoft updates,and switching back to windows update fixes update problems,and vice-versa
Oct 22, 2009 | Toshiba Satellite Pro L300 Notebook
Update contacts new phone number in blackberry pearl 8230 Also, how to access call history and make the back light brighter
Update w/ new number: Go to Address Book, begin typing name, scroll to contact and select, with contact showing press the Blackberry button and choose "Edit".
Backlighting adjustment: Options>>Screen/Keyboard>> adjust the brightness setting (listed in % 10-100). Then press the back button and Save your settings when prompted
Short call history available by pressing the green phone key.
Aug 01, 2009 | RIM BlackBerry Pearl 8130 Cellular Phone
Garmin forerunner 301
oops, i meant i know its NOT the oxidation problem
Jun 29, 2008 | Garmin Forerunner 301
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
