My samsung SP50L2HX tv kept turning off occasionally, with the red LED flashing, after a few weeks of this the picture became very dark and then turned off completely and would not turn on again so I replaced the lamp. now the picture is very very dull, the man at tv repair shop assures me this bulb is correct for my tv but im not convinced, thank you very much
Arpi
  • 326 Answers
SOURCE: Sony Wega 55" Replaced Bulb TV still does not work
Hello, please check how many times the red light flashes. If it is 3 times this means that the lamp cover is not fastened securely. If the red light flashes 5 times this means that the lamp driver is defect. If you need more help please advice
Posted on Apr 20, 2007
SOURCE: Samsung PLH403W Projection TV Lamp Problem
Maybe try removing the dust filter on the back and cleaning it. If I recall correctly the TV won't turn on unless the filter is clean and fully snapped back into position.
Posted on Oct 07, 2007
localwonder
  • 6784 Answers
SOURCE: Samsung DLP seems to turn itself off
HI, this is a weak power board that is causing this shutdown. there is a faulty IC on the board that is unable to correctly distribute the necessary power throughout the set at this time.
Simply replacing the power board will fix this issue. This is not a do it your self so, we recommend a professional service tech for this repair.
Posted on Jun 07, 2009
Axle80
  • 73 Answers
SOURCE: Samsung DLP model hln617w won't turn on (not bad bulb)
Samsung is notorious for having bad color wheels in their DLPs. Well lets just say they are like toasters, they only last a certain amount of time. If the color wheel isn't spinning or is broken, the set will power down almost immediately after you hit the button, you may not even hear the entire fire up jingle. Check the wheel, if you can see the bulb light up for that split second. Actually, check it whether the bulb lights up or not.
Posted on Jun 29, 2009
ladywinn
  • 5138 Answers
SOURCE: Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
Posted on May 01, 2010
Vizio E480i-b2 LED TV loosing picture and sometimes shutting off
I don't think you had backlight issues like you thought you did as the set should have shut down the backlights totally as soon as it sensed over voltage or over current, I'd try a new main board and see if that fixes things up for you
Dec 09, 2017 | Vizio Televison & Video
Samsung LED TV problems
try first with the led strips noo need replacing t-con
Feb 27, 2017 | Samsung UN40ES6100 - 40" 6 Series...
My samsung led tv is getting dark
With a DLP TV, getting a darker picture means it is time to change the bulb.
Feb 16, 2015 | Samsung Televison & Video
When turned on green light flashes and no picture
Check the Lamp if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 2X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Check the ballast if no picture, audio may be present. Screen is completely dark. Lamp LED flashes 3X every 5 seconds, Power LED flashes GREEN for 140 seconds then flashes RED.
Dec 24, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Samsung sp50L2hx no picture
You need to replace the Lamp. You have a bad lamp.
Jul 27, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Samsung lcd tv ltm1755b won't turn on (power light stays red)
Problem: Samsung LTM1755B with only a blinking yellow LED when you try to turn it on.
Solution: I just had one of these come in. I opened it up, and found the U501 capacitor a little suspicious looking, in that it had a deformed top. It was a 470uF 16V electrolytic 105degC 10mm x 12mm. I replaced it with a very good quality 1000uF 16V electrolytic 105degC 10mm x 16mm Nichicon UHN1C102MPD. After that repair, when I tried to turn it on, the LED was yellow for a second, then green, then I got a picture, and it appeared to work great. I then asked the owner a week later how it was working, and they said it was working just like new!
Jul 31, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Lamp problem or else?
You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
I have the exact same TV, did the above this past weekend, and the TV works like new.
You need to know how to solder though. It's not that hard.
Mar 14, 2008 | Panasonic PT-60LC13 Television
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Right 2 inches on edge of screen are darker than the rest of the screen
What is the model of the TV? Samsung DLP TV's start with HLS,HLP,HLW.....
Feb 06, 2007 | Samsung TX-R3080WH 30" TV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
