Question about Canon ZR200 Mini DV Digital Camcorder
When I record Video in canon ZR200 in my memory card the quality is too poor. My mini DV is also struck in the handy cam, service persons are demanding too much money to remove the cassette.
    Sergeant:
    Champion:
  • 338 Answers
I think these firms who tell you silly prices for doing what is simple put these costs on because they dont want to do the work, I was told that a washer was going to cost me £190 on my bath taps, simply because I lived too far out of town and they did not want to take the job on.
By running your tape to and fro a bit (not too far) the door will open.
Posted on May 26, 2010
Testimonial: "Thanks David, I will check and let you know the details. "
Can I hook up to the DW 100 Canon burner with my ZR200 to burn mini tapes on DVD?
No. The Canon USA web site says the Canon DW-100 has a USB terminal and works with "USB 2.0 Hi-Speed (with compatible Canon camcorders only)." In other words, the Canon DW-100 burner works only with Canon's USB 2.0 camcorders. I have a Canon ZR200. The ZR200 has Firewire 400 digital video output, not USB 2.0 output. The USB port on the ZR200 is ONLY for still images. Video will not and cannot be output through the USB port on the ZR200. (Page 121 in the ZR200 manual mentions using the USB port on your camcorder for transferring still JPEG images to your computer.) You need a DVD burner with "DV Input" (also called Firewire 400 or IEEE 1394) to hook up your camcorder to burn Mini-DV tapes onto DVD. The Sony VRDMC10 Stand Alone DVD Recorder/Player has DV Input. The ZR200 camcorder did not come with a Firewire cable, but you can buy one at any electronics store or at a cheaper price online. Make sure that you get the right kind of Firewire cable, 4-pin to 4-pin or 4-pin to 6-pin, whatever the DVD burner you choose requires. (Your ZR200 has a 4-pin DV port on the camera's end.) USB 2.0 Hi-Speed (with compatible Canon camcorders only)
Mar 15, 2011 | Canon ZR200 Mini DV Digital Camcorder
Why does my camera stop recording after one hour? i need to record 90 minutes
Your camera records in two modes: SP and LP modes. SP is a higher quality mode that runs for about 60 minutes, while LP records for 90.
To change to LP mode, open the menu and select [VCR setup]. Select [REC MODE], set it to [LP] and close the menu.
Keep in mind that your video and audio will be of noticeably lower quality with this setting applied.
Mar 08, 2011 | Canon ZR200 Mini DV Digital Camcorder
My playback video jumps after recording on tape also audio lever rises and fall i does not have this problem when record on the memory card i have a canon Zr camcorder
I have seen this problem many times, the recorder unit needs to be replaced, either something in the tape path has become out of alignment or dirty like a capstan motor or gears or the video head assy is defective. I hope this helps.
Sep 04, 2010 | Canon ZR200 Mini DV Digital Camcorder
I cannot turn off the erasure prevention on my memory card. I have a Canon ZR200
Take the card out and look along the edge for a small 'switch'. This switch will have a 'locked' and an 'unlocked' position. Make sure it is 'unlocked'.
Jun 06, 2009 | Canon ZR200 Mini DV Digital Camcorder
Canon NTSC zr200 Mini DV and lost the software to convert the files
download Canon software from here
http://software.canon-europe.com/
May 28, 2009 | Canon ZR200 Mini DV Digital Camcorder
Is the memory stick of sony handy cam minidv trv-18 expandable?
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be tha same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Oct 15, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Cant detect camera on dv video recording transfers.
Hi, I hope the camera you are talking about is ZR200 Mini DV.
As per its specifications. It has a firewire/DV port.
Therefore, follow these steps. I assume you are using this cable. http://cdn.overstock.com/images/products/L10726964.jpg
I am not sure how you used the firewire cable before.
So, try this. Connect one end of the cable to computer and other to the camera. Switch on the camera and keep it in play/ edit mode (not in shooting mode).
When you connect the other end to the computer,  There should be a popup asking you what to do.
If there is no popup,  Open Windows Movie maker and import video from device. You should see the camera in it.
Hope it works.
Sep 24, 2008 | Canon ZR200 Mini DV Digital Camcorder
Low quality image from 2GB chip
Low resolution on memory card recording, regardless of the storage capacity of the card is just the way it is. If you consult the zr600 users manual (p. 82 of my edition - PUB.DIM-734/1205Ni15.1, c2006) you can find that video recording to the memory card is limited to resolutions of either 320 x 240 or 160 x 120 pixels. These resolutions are pretty poor - disappointingly so seeing that one of the old computer monitor standards used to be 640 x 480 and that 1024 x 768 is common today. I was disappointed too.
Mar 13, 2008 | Canon ZR600 Mini DV Digital Camcorder
Canon zr200
This is the description of the feature you need: "Have friends in far-off places? Turn your ZR200 into a Webcam for Internet Video Chat with Microsoft Windows Messenger through IEEE1394. It's all possible thanks to the DV Messenger2 software, available as a free download for ZR200 owners. DV Messenger2 allows you to control the zoom and focus of your ZR200 or the camcorder of the person you are chatting with. Preview thumbnails and transfer photos. You can even watch and control the video playback of either camcorder right from your computer." You can download DV Messenger Version 2 only after registering with Canon, see the bottom of the following page: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=326&modelid=11004 I believe the drivers are included in the download. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | Canon ZR200 Mini DV Digital Camcorder
Canon ZR200 Mini DV Digital Camcorder Logo
249 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
