Question about Video Game Consoles & Games
I have a brand new ps3 while intial set up i hit button on accident it changed language on me and also im stuck where it ask about video,audio,hdmi
  • 33 Answers
If you cant figure out what the words are to be able to get it back to english, goto freetranslation.com and enter in the words that you see on your ps3 and it will tell what it is in english
Posted on Jun 07, 2010
I am unable to get a picture on hdmi when i connect my ps3, but am able to get sound when i use ps3 controller. any ideas ?
Steps
  1. Step 1 Check for an HDMI port Check the back of your television for an HDMI port and refer to your owner's manual for your television's resolution. A resolution of 1080p offers the highest quality.
  2. Most PS3 systems support 1.3 HDMI, but older systems may need a software update from the 1.1 or 1.2 version.
  3. Step 2 Disconnect cables Disconnect all the cables and adapters from the back of your PS3, and then unplug your TV to reduce the risk of shock as you work.
  4. Step 3 Connect HDMI cable Connect the HDMI cable. Reconnect the power cables on both the TV and the PS3 system.
  5. Step 4 Hold power button Hold down the power button until the PS3 beeps and continue holding it for an additional five seconds until the system makes a second beep.
  6. The Playstation 3 should detect the high definition cable and automatically adjust the settings to give you the best picture and sound possible.
  7. Step 5 Test the connection Test the connection. If the HDMI cable isn't working, turn everything off and reconnect the original cables to manually change the settings.
  8. Step 6 Adjust the settings Turn the system back on, select Settings, Display Settings, Video Output Settings, and then HDMI. Repeat the process for your Audio Settings. You can now experience your games with the highest video and audio quality available.
Dec 01, 2014 | Sony KDF-E50A12U 50" LCD HDTV
Using HDMI cant get video from ps3
Check your ps3's audio settings. They come under the settings tab, 7th from the top i guess, not sure. Just play around with the settings until you think the sound problem is fixed.
Jan 02, 2014 | Sony Playstation 3 (PS3) Console
Cant get output ps3 on hdmi cable
  • Make sure the system is off.
  • Hold down the Power Button for 5-6 seconds - until you hear the second beep.
    This resets the video settings to defaults (standard video output).
    Power up the PS3 again and it should auto-detect the hdmi at this point.
    If that does not work use the original audio/video cable that came with the system, power it on, then adjust the video settings and try the hdmi cable again.
  • May 18, 2012 | Video Game Consoles & Games
    Playstation3 has been converted to play 3d but now wont project an image does it require a hdmi cable
    OK sometimes people put the HDMI cable to the PS3 and it changes the settings. Try to reset the ps3. Turn the ps3 off with just the red light showing. The hold the power button. when it beeps and the light changes keep holding it. then you with hear 2 to 3 beep right after another. When you do let the button go. The does a manual reset and whatever cables you have connected at the time should work. If this doesnt then your video card on the board might be out. I hope this helps you out.
    Dec 01, 2011 | Sony Playstation 3 (PS3) Console
    My hdmi doesent work
    While the console is off, hold the power button until you here it beep several times. This resets the video and audio output. The PS3 will power up and it will ask you what type of connection you are using for audio and video.
    May 09, 2011 | Sony Playstation 3 (PS3) Console
    Setting audio to optical makes hdmi video not work
    Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
    Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
    Dynex tv works. bought ps3. when hooked up to
    I would suggest you check if your PS3 is set up on going through the HDMI Cable.On your PS3's XMB scroll to settings -> Display Settings -> ANd from there go down to the one that says "Y Pb/Cb Pr/Cr Super-White (HDMI)" and hit X and select the option Yes... That sets the PS3 displaying through the HDMI
    If you are already have done that I'm pretty sure you know you have to change the Input on your TV to HDMI... Take your remote and hit Input -> Scroll down to HDMI on the Input Source menu and hit Enter when you get to HDMI
    If the AV on your PS3 works and not your HDMI sounds like Display Settings issue...
    If you have done all that, that is strange if it still doesn't work.
    There are some people that are having problems with the AV Cable with the PS3, I tried this and it really does work. I switched from HDMI on one tv to a AV Cable on another and when I did that neither TV would display content from my tv. The fix for this is resetting your PS3, like on a iDevice you hold the home button and lock button, for the PS3 you hold the Power off button and the Eject button for around 10 seconds. This resets your PS3 into default video settings. Until it Turns on, Beeps, and Turns off. This should work.
    Jan 01, 2010 | Televison & Video
    No audio
    stupid answer but did u check the audio settings in the main menu from the ps3? i reset my ps3 on accident n the audio changed to component but picture stayed on HDMI
    Jul 13, 2009 | Sony Playstation 3 (PS3) Console
    PS3 hdmi Audio problem Crackling Sounds
    I CHANGED THE AUDIO SETTING UNDER HDMI FROM AUTO TO MANUAL AND I REMOVED DOLBY 5.1 FROM SELECTIONS.LEFT THE OTHER 2 SELECTIONS THAT WERE ALREADY SELECTED FROM AUTO SET FOR HDMI I HAVE NOT HAD AUDIO PROBLEMS SINCE.
    Nov 05, 2008 | Sony Playstation 3 (PS3) Console
    It wont run through HDMI
    Follow the guy aboves solution to reset your Ps3 to 480i. Turn the power to the system off from the switch on the back and then when you flip it back have the power button held down on the front of the system. This only resets the picture doesn't change anything else or erase any games, I had to do it and it works!!
    Oct 22, 2007 | Sony Playstation 3 (PS3) Console
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
