Question about Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by
I have a Moen Monticello bathroom faucet. The elbow is loose onto the hub and I can't figure out how to tighten it. Thanks.
4 Suggested Answers
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
  • 30 Answers
SOURCE: My Monticello has a loose handle.
If you click on the "Illustrated Parts Diagram" link in the link attached, you will see in the link below how you just need to twist the elbow in order to tighten it onto the hub.
Posted on Sep 22, 2009
  • 3 Answers
SOURCE: I have a Moen Monticello bathroom faucet. I am
Moving left to right: I am not an expert, but I have installed a fair number of faucets. Seems like a basic issue of just getting under the sink and tightening up. Make sure someone is topside to assure the faucet stays straight and does not move as you tighten up below. It is never easy to get a wrench and your hands in the proper position to tighten up the nut, but don't give up try a smaller Channel lock wrench if necessary.
Sink Stopper: http://www.lowes.com/lowes/lkn?action=howTo&p=Improve/PopUpStop.html
Posted on Jan 03, 2010
How do I replace handle adapter kit for Monticello?
Unthread the handle hub (ccw), once detached, turn the handle upside down. There is a Phillips screw inside that once loosened (ccw) will allow you to replace the adapt.
Feb 18, 2015 | Moen Bathroom Sink Faucet - 4-inch...
Water leaks from under hot water side when turned on moen 4570
There is a nut on the top of the valve the stem goes through. Tighten it.
May 11, 2013 | Moen Bathroom Sink Faucet - 4-inch...
Replacing the handle adapter on a 4-inch moen monticillo bathroom faucet. Can't get the handle hub to unscrew with a strap wrench. tried using lime away to cut the 15 years of crud around the handle...
Sometimes there is a small set screw located on the handle.It takes a small allen wrench to loosen it.That should enable you to remove the handle assembly.
Jun 03, 2011 | Moen Bathroom Sink Faucet - 4-inch...
Just purchased the home and the handle on the moen 4551 cp is loose. The handle actually falls off the fixture. There is a plastic grommet or washer that is broken. How do I replace this plastic grommet...
You can find the parts diagram here: http://www.moen.com/monticello/chrome-two-handle-low-arc-bathroom-faucet/_/R-CONSUMER%3A4551 . The washer kit is part number 97274. The lever and the hub and elbow that the handle connects to depend on the finish and whether you need the hot or cold side replaced. Levers: 97557 Chrome 97558 Pol. Brass, hub and elbow: Cold 100552 Chrome, 100552P Pol. Brass; Hot 100553 Chrome, 100553P Pol. Brass.
You may be able to find the washer at a local hardware store (like Ace or Tru-Value). Alternatively, call Moen or visit the Moen site. 1-800-BUY-MOEN or http://www.moen.com/replacement-parts/product?product=IMGLIB:CA84437BN to order replacement parts.
You'll have to pay for the washer kit. However, if the hub and elbow or the lever are damaged, call Moen and see if they will replace it under warranty.
I hope this helps.
Mar 08, 2011 | Moen 4551___ Monticello Popular Two Handle...
Handle is loose water flow weak
to tighten handle, you hold lever(top of handle) while unscrewing round piece below, entire assembly should come off.look down and should be screw down there, tighten it up. flow problem could be the areator, unscrew and clean if need'd. check supply tube's,shut off valve's, (if you have them)make sure they are wide open.
Mar 22, 2010 | Moen Bathroom Sink Faucet - 4-inch...
I have a Moen Monticello type T4572CP bathroom faucet that has a loose hot water handle.How do I correct problem.Thankyou
Pop off the plastic cover in the center of the handle to find a screw that you can tighten
Feb 26, 2010 | Plumbing
Jan 02, 2010 | Moen Bathroom Sink Faucet - 4-inch...
Loose handle
There should be a set screw that will tighten up handle.
Oct 02, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Sep 20, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Moen Bathroom Sink Faucet - 4-inch Centerset with Drain - Monticello by Logo
85 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
