Question about HP Compaq nx6110 PC Laptop
HP COMPAQ NX6110 LAPTOP HANGS WHEN BOOTING, BUT WHEN PRESSED AROUND THE MOUSE PAD OR HARD DISK AREA IT WORKS , BUT HANGS AGAIN LATER
    Novelist:
  • 83 Answers
It seems that the hard drive or the memory module is not seated properly and hence after pressing on the area below keyboard it gets released.
You can try following things.
Remove and reseat the Hard drive.
And remove and reseat the Memory.
Try to power on the laptop again.
If is getting hang again then you may need to do the HDD self test and memory test built into BIOS.
Posted on May 28, 2010
Pxe-e61 on my hp compaq nx6110, wont boot up!
If your laptop used to freeze up at random, the mouse and keyboard did not respond at some times or you experienced longer and longer boot times with the HP logo on, then your laptop is suffering from a motherboard failure. The options are either to get a new motherboard, or repair the one you have. Here's a great repair tutorial for non booting or random freezeup HP nx6110. The repair does not require any tools, except for a Torx screwdriver, and it usually takes about an hour to do the fix. If that doesn't work then you'll have to use a hot air gun and do a reflow of the FSB chip.
What happened is that in time, the FSB controller chip lost contact with the motherboard and since the FSB controls the hard drive, dvd, keyboard, mouse and so on, the laptop cannot boot. The repair tutorial will help you to re-establish contact between the chip and the motherboard, but you will have to open up the laptop. It's not a difficult repair, but if you're not very handy with tools, you may take the laptop and the tutorial to someone that can do the work for you. It's better to be safe than sorry.
If this post was informative and helpful, please vote with a Thumb Up. Thank you.
Jan 19, 2011 | HP Compaq nx6110 Notebook
My HP compaq nx6110 windows xp sp3 hangs at boot
Take a look at this post that deals with a HP nx6110 laptop with random freeze ups. If the described symptoms also happen on your laptop. If you do experience random freezeups or slow DVD you're facing the same FSB chip problem. All peripherals, USB ports included, are connected on the Front Side Bus. Poor soldering causes intermittent contact which in turn results in hanging, slow, or totally non bootable (stuck at HP logo) laptop. Hope this helps.
Nov 14, 2010 | HP Compaq nx6110 Notebook
My laptop usually hang during booting, until i press down the side of the processor before it continue
This problem from the chipset .. this is a big chip ic u need to remove reball and fix it again... u can if it under the mouse pad.. when u open laptop ..Thanks
Sep 08, 2010 | HP Compaq nx6110 PC Laptop
I got 256mb internal ram and i put 1gb external ram on my hp compaq nx6110 laptop and after few months my hard disk stops working. so now i want to buy a new hard disk so how many gb of hard disk i should...
I think you're confusing RAM (memory) with hard disk space (storage). Installing more RAM makes your computer run faster. More hard disk space gives you more room to store stuff. Which would you like to do?
Apr 03, 2010 | HP Compaq nx6110 Notebook
My compaq nx6110 keeps on hunging randomly ,but when you press somewere near the touch pad it becomes normal
its due to two reason
1,hard disk failure first stage
2,virus
for virus you have to do following steps
1,download spybot from the internet
2,install and scan
3,fix selected problems
Nov 01, 2009 | HP Compaq nx6110 PC Laptop
Hp nx6110 laptop keeps hanging but works well when pressed on top of touch pad or hard drive.
Only if you have knowledge on hardware Laptops you understand. The procedure go as follow:
Unscrew the motherboard completely.
Identify the North-Bridge BGA IC (BGA= ball grid arrays) under the mouse region.
Get an SMD Rework Station.
Suspend the board on a surface which cannot be affected by heat and held firmly whereby under the North-Bridge BGA IC is opened.
Use your SMD Rework Station to generate heat  evenly beneath the region North Bridge IC and press gently without being bridged.
Mind you 90% risk is involve.
Oct 07, 2009 | HP Compaq nx6110 PC Laptop
hmmm..that sounds like a motherboard problem about to happen. you have warranty coverage on this unit? also, you may wish to turn over the computer, remove battery, get static off your hands, then remove and reseat the memory cards underneath(most likely behind a small panel with a small phillips head screw).
Laptop keeps hanging
TRY TO BACK THE OLD ONE IF IT IS OK THE NEW ONE ARE NOT COMPATIBLE
Aug 18, 2009 | HP Compaq nx6110 PC Laptop
My laptop compacq nx6110 hang i hv to press the motherboard
this problem is hardware related, this problem caused by the chipset "intel 82801 fbm" . if you have an electronics experience,
remove the mother board,
find the chipset intel 82801 fbm
reflow the chipsett by "bga rework station" or "hot air blower"
then refix and check the system
Jul 04, 2009 | HP Compaq nx6110 PC Laptop
Keyboard not responding
Boot in safe mode
>control panel
>Printers and other hardware
>Keyboard
>check to see if is has been disabled
??>does you mouse pad work
>If no plu a USB mouse in 1st before you boot into safe mode
Aug 28, 2008 | HP Compaq nx6110 PC Laptop
HP Compaq nx6110 PC Laptop Logo
647 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
