Question about Garden
Hi, I have a flymo venturer 320 lawn mower, I was cutting my grass and went over a stone, and now it wont work at all! any suggestions pls?
  • 1,383 Answers
THE KEY IN YOUR FLY WHEEL IS BROKE , SO IT DON'T BEND OR BREAK THE CRANKSHAFT THIS IS WHAT ITS THERE FOR. REMOVE FLYWHEEL AND GO TO ACE HARDWARE $ ABOUT A BUCK .. .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
Posted on May 26, 2010
Why is my lawn mower losing power after new rocker arms fitted.
may be set the rpm up a little to help with the thicker grass
Jul 23, 2016 | Husqvarna Garden
Flymo instruction manuals
www.flymo.com/uk/robotic-lawnmower-support
www.flymo.com/uk/contact-us
Jul 14, 2014 | Garden
Why wont my Flymo qs 46sd rev ?
does it have a throttle cable fitted?? you really dont need an idle as as soon as you release the opc or dead mans handle it will cut out anyway. engine should be reving at 3000-3100 rpm. if this mower has a briggs and stratton engine fitted, remove the air filter and check the spring and linkege is still attached to the air vane govenor
May 20, 2014 | Garden
Why does my flymo switch off when grass box is only half full?
sound like a bad pressure switch or sensor, try cleaning or washing the bag, inspect for broken wire.
May 17, 2014 | Garden
Why is my flymo 360 eg not collecting the grass
If you have changed blades or have low lift blades this will be the problem. For good grass collection you should have high lift blades
Apr 30, 2014 | Garden
Flymo 340 - just bought it and it doesn,t seem to cut the grass at all whichever setting it's on.
check to see if the blade isint upside down pull the plug wire so you dont have an accidental pop or start pull the cord see what direction its going in
Apr 11, 2010 | Electric Garden
Flymo compact350 electric grass cutter motoris
Check for debris caught under the deck. The motor may be getting ready to quit. The machine may need a replacement belt. Be careful and unplug the machine before checking.
If this is helpful, Please leave Feedback.
Thanks, SnugglePants
Oct 27, 2009 | Garden
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
185 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
