Question about Smeg 23 in. SA435X Electric Cooktop
My smeg SE2640TC1 cooktop is cracked and we need to replace it. How do we go about doing this - (ie hardwire etc)
  • 8,197 Answers
To replace the cooktop the first thing you need to do is turn off the breaker outside that supplies the power to the cooktop.. Then go under the cooktop in the cabinet and follow the flex power cord to the wall. Remove the cover plate on that box in the wall. un connect the wires from the wires in the wall. Next look up at the bottom of the cooktop to make sure there is no clamps that hold the cooktop to the counter top. if there is remove the. Then just lift the cooktop off the counter top. from here you just reverse the steps to put the new one in.
Good Luck
Posted on May 26, 2010
Smeg mod nu.sar93xlpg gas cooktop is 20 years old and in good condition The gas igniter recently has been sparking once every 5 mins. works fine except one spark every 5 minutes,any ideas
probably find that after so long the igniter is starting to fail
call smeg and see if there is a replacement one available
there may be after market units from your local gas shop
Jun 25, 2016 | Smeg Cooktops
Smeg hob cracked on the bottom left side. It still works perfectly, however I'm wondering if I can just replace the glass, or if I need to replace the whole thing? Im looking for the cheapest option
The cheapest option is to araldite the crack (assuming it's not over the hot part!) and live with it. I doubt it is economically viable to replace the glass, it will be quicker and easier to replace the hob if you can get one with the same hole size. The only way it would be cheaper is if you find a second hand one on an auction site. You might be covered on your buildings insurance but a claim won't be cost free.
May 12, 2014 | Smeg 23 in. SA435X Electric Cooktop
New cooktop ! long flame yellow tips black deposits on pans
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
Nov 03, 2013 | Smeg 23 in. SE64 Gas Cooktop
Smeg gas cooktop is continually clicking.....going mad,,,,,
Ist unplug the unit. What you have is the stovetops valve switch defective. Sometimes this will happen after a boil over. The switches get wet and temparaly short. When they dry out it should work properly.http://www.on-timeappliance.com/ovenrepair.html
Mar 26, 2012 | Smeg 23 in. SE64 Gas Cooktop
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
SMEG SE435X-1 60CM Electric hob. Keeps tripping fuse
It's possible that one of the burners stay on for a long time, which cause one of the wires to overheat, breaking the connection and touching the body of the unit, please turn the breaker off and check for a loose connection, replace the wiring if you feel confortable doing it yourself or contact a technician.
Jan 06, 2010 | Smeg 23 in. SA435X Electric Cooktop
SMEG gas cooktops quality CIR597X in particular
yes is ok the brand..but if u nid same quality but cheaper price get other brand like indesit,ariston,or glemgas.also have an nardi,jollynix ignis..check all the item u want to buy then compare wat diiferent of all..sometimes different brandbut same quality also same part inside.
tnx gerbee
Sep 13, 2009 | Cooktops
Ignighter is not working on any burners
if if does not light anymore you have a ignition sequence fault could be a faulty switch foe the ignition pcb ht lead or electrodes
Aug 21, 2009 | Smeg HB96CSS Gas Cooktop
Smeg 23 in. SA435X Electric Cooktop Logo
679 people viewed this question
Top Smeg Cooktops Experts
ray gallant
marlin siecinski
Bill Boyd
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
