Question about Freezers
Changed thermostat worked 4/5 days and defrosts again
Hi I have a westinghouse silhouette upright freezer model fj383G.
the fan is working but its not freezing. We changed the thermostat and it was working fine, but after four or five days the food starts defrosting. what could be causing this?
  • 523 Answers
Take back of freezer out does the coil have a full frost pattern? make sure the bulb to the t stat is where it needs to be and make sure they didnt give you the wrong one it might be a frig stat
Posted on May 26, 2010
Where can I download a service manual for my Westinghouse Upright Freezer Model FJ303 as I think there is something wrong with the defrost system
Go to Westinghouse web site and see if they are available there. If not , call them and have themsend one. Your defrost system is should be defrosting 2-3times a day. Is it not defrosting at all or is there an ice buildup.
Mar 02, 2013 | Freezers
Fan on freezer won't com on but freezes food on
Hi and welcome to FixYa, I am Kelly.
There are 12 midelos that fall under the model number you passed. I will cite EV171NYMQ05 as a reference model number via this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769
The freezer fan should be on anytime the compressor is on. If there is an ice block built up on the evaporator coils it can lock the fan blade in place via the ice build up. Additionally... if the fan motor bearings are dry or coated with sludge this too can prevent the fan motor from operating. The fan motor is item 3 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28174432#d28174432
Detail views:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-motor-evap-item-number-ap4539455.aspx
To check the can motor all that is required is a simple continuity check across the 2 connector wires. You should read under 480 ohms.
If you discover that the fan blades are encased in ice... do a manual defrost: (be ready to tend to a water mess)
1. By first unplugging the unit and then removing the freezer contents.
2. Direct an external fan into the freezer compartment for just over 2 hours.
3. Make sure the compartement drain funnel is clear of obstructions. Item 11 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28158051#d28158051
After the 2 hour manual defrost period plug in the unit and test to see if the fan motor is running.
If it is running you may have an automatic defrost problem causing the ice build up. On a freezer the ice build up will start again if there is an automatic defrost problem in 3 - 5 days. Until the automatic defrost problem is corrected you will end up doing the manual defrost routine described above everytime you have improper cooling problems.
Components that can cause the automatic defrosting problems are
1. The defrost timer item 7 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140769&diagram_id=28257341#d28257341 Because it is not cycling or stuck in one position.
2. The defrost bi-metal thermostat item 9 above link (stuck closed)
3. The defrost heating element item 5 above link. (open)
And of course internal wiring....
Check the fan motor for continuity... if you attempt to lubricate it which is very difficult on this fan motor make sure you use paraffin based "Turbine oil" and not a regular household or automotive oil. Using any other oil will cause the fan to stop working in as little as 30 days.
Thanks for choosing FixYa,
Kelly
Jul 08, 2011 | Whirlpool 16.7 cu. ft. Upright Freezer...
Frost on wall
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Jul 17, 2010 | Woods Freezers
Ice builds up in the freezer
Take care
Jul 17, 2010 | Woods 201 cu. ft. Upright Freezer V2003RW3
I'm having things freeze in the fridge side not sure what to have the temp set at
Set the temp at 4 and then close the vents a little coming in from the freezer if you have any. If this doesn't work then your thermostat may need replaced. Also always for good measure>>>>
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 13, 2010 | Frigidaire Freezer Refrigeration White...
Ice build up In GE Tnx22brcalbb stops fan from circulating air.I can remove the ice and freezer will work for several days but ice builds up again.
there is a problem with your defrost circuit.you also need to check for any bad spots in your seal that maybe letting air in the freezer causing excessive ice build up.but you need to check your defrost sensor
Feb 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Kenmore 14CF upright freezer will die after a day or so
The defrost timer is faulty or you have a defrost circuit short, unplug remove back panel inside the freezer and check for a short in the heater and defrost thermostat.
Dec 30, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
Sep 11, 2008 | Frigidaire Freezer Refrigeration White...
Not Freezing, but cold
The thermostat should be a close circuit when requesting cold temps. or when asking the compressor to come on. The exterior surface on some freezers warm when asking for cold inside. Yours has a condenser coil on the back and that should warm when cooling. If compressor is runningit should be wrm if no freon has leaked from freezer somewhere.
The defrost timer should rotate clockwise during the day and give approx. 3 defrost daily or about every 8 hours. Until the thermostat is resolved and asks for a closed circuit the compressor will not come on. Unplug freezer from outlet,remove thermostat wires, then turn the thermostat to its coldest setting and check again. If no closed circuit the thermostat will need replaced first. Hope this has helped you, Sea Breeze
Nov 01, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Freezers Logo
181 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
