Question about Refrigerators
I have a GE Profile side by side refrigerator model TFX27PF. The coils behind the panel in the freezer section do not automatically defrost as engineered. I have to take off the back cover and manually defrost the coils. After defrosting the normal light will come on and remain on for approximately 3 days. Then the def indication will come on in the status window.
  • Don Kennedy May 27, 2010
    The defrost heating coil does not energize so the frost on the coils builds up. I have to unplug the refrigerator to defrost about every 8-10 days. What components in the electrical circuitry control this process.
    President:
  • 1,554 Answers
Since you have accessed and defrosted the evaporator coils, check the resistance of the defrost heater, and the continuity of the defrost thermostat. Replace the defrost heater should it read open and the defrost thermostat should it read open. The defrost timer is not working if both the defrost heater and thermostat turn out to be in good operating condition.
Posted on May 27, 2010
  • 821 Answers
Hello,the problem you are having arouse as a result of ineffectiveness of both the compressor and the fan.so all you need to do is just to give them a proper servicing to make sure they are in order.you can also visit the site below for a more comprehensive instruction.
http://www.applianceoutletservice.com/appliance-care-tips/refrigerator-tips/refrigerator-defrost-system-information.htm
wish you good luck,
take care.
Posted on May 26, 2010
WHY THE FREEZER FUNCTIONS BUT THE REFRIGERATOR SECTION DOES NOT FUNCTION ON A GE PROFILE BRITA FRIDGE?
Check for failed evaporator (cooling coil) fan motor, located in the freezer or a failed component in the automatic defrost system.
Sep 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
Defrost light flashing on my TFX27PF
Ordinarily, that's an indication that the automatic defrost function has failed. If not corrected, the evaporator coil will eventually ice up and cause the freezer temperature to rise.
On older models, the most common cause is a worn out defrost timer. Easy to replace and not particularly expensive.
On newer electronically controlled models, expect to replace the (Chinese made) motherboard. Expensive, and the replacement won't be any better quality than the original.
Mar 13, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by Side GE Refrigerator freezer will not defrost which allows frost/ice to build up. I have cleaned all the areas behind the unit as well as under the unit. After I manuely defrost the freezer it...
The defrost circuit has failed in your fridge. Typical failure is with the defrost heating element. To troubleshoot, you need to remove the remove the contents of your freezer section and remove the freezer back panel to access the evaporator coil. You will need a hair dryer to melt the ice on coil. The heating element is attached to the coil. Use a meter to confirm that the element is bad. Hope this helps you.
Nov 08, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water) Make sure water drains when you pour it in. If it doesn't - also clean drain tube on the back of the unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First Choice Appliance
Apr 19, 2010 | GE Profile TPX24PBDCC Side by Side...
I have a profile ge freezer on bottom and the freezer is very cold and refrig is 68
check that fan is turning.
if stopped it may be from ice behind panel.
then check for defrost issues
usually bad defrost thermostat (round disc by heating coils that melt ice
Oct 27, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refridgerator not cooling enough, freezer working fine.
The profile uses the mother board to signal defrost. Most times the defrost heater is the problem. If your refrigerator is not defrosting it will cause ice to build up on the evaporator coil behind the rear panel of the freezer. If this is happening the rear panel will show a layer of frost building up on that rear panel. If you see this then unplug remove the rear panel and defrost with a hair dryer until you can have a look at the defrost heater located at the bottom of the evaporator coils. On your model the defrost heater is surrounded by a glass tube and will be easy to spot if burned out. Let me know what you find, Sea Breeze
Aug 23, 2009 | GE Profile¿ Arctica® Energy...
GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Jan 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge Profile refrigerator
Yes your refrig is not defrosting automatically. You can start by removing the shelves in the freezer than removing the rear panel (the panel that is frosted half way). Use hair dryer to defrost ice from coil. This will restore your refrig temporarily. Your refrig has a pretty advance defrost system and is not easy to test. If you have a meter (volt-ohmmeter) i can help with diagnosis.
Oct 10, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
