Question about Philips 42PF7320A 42 in. Plasma HDTV
PLASMA PHILIPS MODEL NO 42PF7320/98 SERVICE CENTRE SAYS THAT SSB BOARD HAS TO BE REPLACED . PLS GIVE SOLUTION. PLS GIVE COST OF SSB BOARD KISHORE THUTHEJA 09823068520
  • 1 more comment
  • kishore thutheja Apr 07, 2008
    LOOKING FORWARD TO BUY SSB BOARD WHICH WILL SUPPORT MY PLASMA PHILIPS MODEL NO 42PF7320/98
  • kishore thutheja Apr 14, 2008
    I NEED PHILIPS PLASMA SSB BOARD NO. 310432838731s PLS GET ME BEST QUOTE
  • asif raza
    asif raza Dec 01, 2008
    HI .my tv light up green then goes red. what is this problem.help me
  • 4 Answers
Philips hdtv 42pf7320/98
in power suplly change both capestor of 3.2 volt supply(3300uf/16v)
it will be ok
asifrazi
Posted on Dec 11, 2008
  • 3 Answers
You need to post the part number off the board. Most of them are 310432842631 for the A/37. Best found on eBay.
Posted on Apr 13, 2008
  • lostin808 Apr 13, 2008
    Ebay cost is $179 to 225 plus shipping
    New Friend:
Byo deta
Posted on Dec 17, 2012
My tv had similar problems. It would seem the original factory cooling fan inside the unit is insufficient.This causes an overheating condition. Strange as this may sound, try putting a standard fan in the rear of the television close to av input jacks,and let it blow on the back of the machine.If the machine ceases to act erratically,this is the problem. If this works,consider installing larger, more powerful internal fans.
Posted on Mar 29, 2009
I have Videocon Plasma Model, problem in plasma Panel y board panel r as per the videocon servicing centre. Part detailos are- yd 07 Samsung panel? Should i replace it or think for new TV? What will be...
IF YOUR Y BOARD IS SHORT YOU WILL HAVE TO REPLACE THE TWO Y BUFFERS THIS WILL COST TO MUCH THE EQUIVELENT OF YOUR TV IS 430 WITCH COST ABOUT 600 DOLLARD
Nov 17, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
Philips TV will not tune
yes its SSB board is faulty, Replace complete Board or just replace is EEPROM
Nov 12, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Ssb for my philips plasma
hello,
the ssb stands for small signal board and is where the microprocessor and eeprom are located. also tuner is on that board. these are not component level repairs therefore circuit board would need to be replaced. costs very but to be honest can vary from 300 to 1000 dollars from my experience depending on where your able to get the part. andrews electronics and vance baldwin are main distributors for philips parts but if you google part number may find renewed part available. part number is going to be located on tuner. should be 3 12 numeric numbers on tuner. top number with s to left is correct number. hope this helps. dan
Aug 14, 2008 | Televison & Video
I need help tv plasma phillips
There is a firmware that can be updated via usb from philips. This fw was used to correct the tv powering on with no picture randomly (they called it a maintence session) but it was a problem. The tv would power on on its own and do this..
If that doesnt take care of your problem then the problem is with the main control board. or ssb
Aug 01, 2008 | Philips 42PF9630A 42 in. Plasma Television
Philips 42PF5321D/37 Error Codes
replacing ssb for 4 blink error was correct as error is communication failure specific to micro processor on ssb. getting an alternate error after replacing ssb would suggest either wrong ssb or defective ssb. verify vendor number on ssb tuner on original and new ssb and if same reorder that board and if not order per original board
Jun 30, 2008 | Philips 42PF9630A 42 in. Plasma Television
PHILIPS SSB BOARD
Look on ebay.com cheapest price I found and that is where I got mine.
Apr 17, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
PHILIPS PALSMA TV SSB BOARD
I was unable to locate the part number 310432838731. The SSB board for model 42PF7320A is located below.
Philips 42PF7320A Replacement Small Signal Board
Apr 14, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
No video
PROBABLY NEEDS SSB REPLACED BUT YOU WOULD HAVE TO DO SOME VOLTAGE TESTS TO BE SURE
Feb 19, 2008 | Philips 42PFP5332D 42 in. Plasma...
Ssb board
What model is this? Because it says Magnavox 27ms343s which is a 27' tv. The 55' has a different board. Small Signal Board is SSB, you also have a LSB. Your best bet is to call 1-800-844-7871 which is PTS and give them the model # and order the board. It will be the cheapest you can find. If that person is right then you can get the board here. And even if you have question you can ask to speak to a tech and give them the problem. Hope this helps
Sep 13, 2007 | Philips Magnavox 27MS343S 27" TV
Philips 42PF7320A 42 in. Plasma HDTV Logo
968 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
