Question about Saws
Wrong floor tile adhesive used. Contractor used timber floor adhesive instead of concrete. Some tiles cracking and adhesive not drying?
You can choose a kind of super tile adhesive, it can stick all kinds of tiles. Maybe can solve your problem.
Posted on May 28, 2011
    Novelist:
  • 145 Answers
It depends on what kind of tiles they were. If they were soft tile, then they may crack anyway if the floor is not level, also if he made the floor uneven by using the adhesive they can crack. Many soft tiles are peel and stick and no adhesive is needed. If they were hard stone tiles then he should have been using grout to stick them down and grout the cracks in between as well. It sounds like you need to have someone else come in and re-access the problem as I can't see the whole situation, but it sounds like the tiles may need to come back up. You can either get the same guy to come back and fix his mistake or get some one else to fix it then go after him to messing it up. If you want to choose another person I recommend looking at www.superpages.com.
Posted on May 26, 2010
How do i stop shower tiles continually coming loose?
use the correct tile adhesive for the application
look for one that when dry is not affected by water
some are for floor tiles in showers and others for wall tiles
talk to a shop that sells tiles and they will advise of the correct adhesive to use
Oct 03, 2015 | Home
Our self sick vinyl tile won't stick what can you do to get it to stick? We are just installing.
are you putting this over concrete? Is the concrete "clean" meaning your not putting it over glue. I am guessing if this is a new install it is a problem with the floor itself.
Feb 21, 2015 | Building Materials
How do I smooth old flooring adhesive enough to put new floor tiles on it
Depending on the size of the room you should use a floor sander or a buffer with a abrasive pad to smooth the serface to your liking
Mar 11, 2014 | Building Materials
Floor tiles
a friend of mine just asked me the same thing. you could use some adhesive go to home depot and see what there best stuff is !
Jun 07, 2013 | Building Materials
My apprentice used grout, intead of thinset to bond 250 sq ft of quarry tile to concrete. Is there a away to fix it? without pulling all the tile?
Grout is a non-adhesive concrete material that is made with sand and cement, with colorants added.
Grout will not adhere tile to any surface
The good news (if that's possible) is that the tile should be fairly easy to remove, and the grout will be fairly easy to scrape off the floor. Break one tile out of the way, and see if the others can be pried up easily.
Looks like you have to start over, sorry for that.
I was a contractor for 30 years >>> we laid tile for about 2 years and then shifted to other trades >>> I know from experience that the big disasters become great stories a few years later >> every contractor has those stories.
Let us know how it comes out.
Oct 19, 2010 | Q.E.P. Co., Inc. Qep 60024 24"...
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Oct 05, 2010 | Home
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 | Plumbing
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 | Home
Saws Logo
142 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
