The remote will not turn on the tvwhen the power button is mashed. it won't do anything
This is a tv and a built in VCR player
The remote will not turn on the tv power...
Posted on Sep 04, 2008
How to reprogram a universal remote control?
http://www.youtube.com/watch?v=fXDdeXmJjfM
http://www.remotecentral.com/features/remotes.htm
Instructions
    • 1 Find the brand of the universal remote you own on Internet sites like Remote.com (see Resources below).
    • 2 Click on your universal remote brand on the website to find the code list for that remote.
    • 3 Check to see if your remote is preprogrammed to operate your TV, VCR, or Cable Box using the following codes: TV - 000, VCR - 000, Cable Box - 000, AUX - use VCR code 037.
    • 4 Manually turn on your device. Hold down the "Code Search" button on your remote, then press and release the device button you want to set up until it flashes.
    • 5 Push the power button repeatedly until the device turns off, then hit "Enter."
    • 6 Press any other button while the device is on to see if the device responds. If it does, you don't need to do any other programming. If it doesn't, repeat steps 4-6.
Read more: How to Reprogram a TV Remote ' eHow.com http://www.ehow.com/how_4454612_reprogram-tv-remote.html#ixzz1mji7B48P
Feb 17, 2012 | Sony DVD/VCR Combo Player
How do i program my remote
Hello;
Without knowing the codes for the specific brand names and models of your devices, this is how you program the Zenith MBR3447 for your TV, VCR, DVD Player, CD Player or Audio Receiver:
TV
1. Push the "Power" button on the TV to turn it on.
2. Press and hold the "PRG" button in the upper left corner of the remote. Release when the indicator light, located in the top center of the remote control, comes on.
3. Push the "TV" mode key located at the top of the remote.
4. Enter 0 -- 0 -- 0 on the remote's number pad, then press the "Enter" button.
5. Aim the remote control in the direction of the TV's IR sensor and push the "Power" button. Pause a second. If the TV fails to shut off, push the "Power" button again. Repeat until the TV does shut off. Each time the "Power" button is pressed the Zenith MBR3447 tries using a different TV device code from its code library to turn the TV off. Therefore, when the TV finally does shut off it's an indication that the remote is temporarily programmed with the correct device code to control the brand of TV you're using.
6. Press "Enter" to save the current code.
VCR
1. Push the "Power" button on the VCR to turn it on.
3. Push the "VCR" mode key located at the top of the remote.
5. Aim the remote control in the direction of the VCR's IR sensor and push the "Power" button. Pause a second. If the VCR fails to shut off, push the "Power" button again. Repeat until the VCR does shut off. Then press "Enter."
1. Push the "Power" button on the device your programming the remote to control to manually turn it on.
3. Push the "AUX" mode key located at the top of the remote.
5. Aim the remote control in the direction of the device's IR sensor and push the "Power" button. Pause a second. If the device fails to shut off, push the "Power" button again. Repeat until the device does shut off. Then press "Enter."
Mar 11, 2011 | Zenith MBR3447 Remote Control
My 1.5 IR Dish remote has all of a sudden stopped working with our Sanyo tv. I've changed the batteries. When I push the power button it will only light up the VCR button if anything at all. Our other...
sandyannsamp
If the VCR button lights up when you press the Power button, you are not in the correct mode to operate the TV. If the remote is programmed correctly, when you are in SAT mode, you can press the large RED button to turn your receiver off/on. The RED TV button will turn your TV off/on. I have provided links to program your remote to your TV again. I have also provided codes for your Sanyo TV.
Instructions to program your remote to your TV (begin with step 6):
http://www.dishnetwork.com/SupportSection/remote-setup
Here are the TV codes: 590, 683, 589, 542, 652
I hope this helps.
Ray Calo
DISH Network
Nov 18, 2010 | DISH Network IR Remote Control
Hi Iam trying to program a universal remote control to my sansuni tv vcr dvd combo but haven't had any sucess. I have tried to do it with several different universal remote but none of the codes seem to...
How old are the remotes relative to the TV in question? If the remotes are older than the TV or were programmed within 6 months of this TV being released, then the code you need wasn't included in the remote's programming. In addition, unfortunately, many universal remotes do not work on combination TVs (with the DVD player and VCR built-in).
You can try to search through all the codes for the remote if your remotes have that feature. (On RCA remotes, turn on the TV, press and hold the Code Search button until the indicator light comes on, then press and release the TV button. Then press the On/Off button repeatedly until the TV turns off. Press Enter and see if the other functions of the remote work. If they do not, repeat the search. Then do the same but press the DVD and VCR buttons instead of the TV button.)
More likely you need a newer universal remote, a programmable (via computer USB) universal remote or a substitute remote from the manufacturer. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12845952409830&smodel=TDC2075&brand_pn=SANSUI_TDC2075 for an exact substitute remote that will replace the original remote.
I hope this helps.
Sep 15, 2010 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
Unable to control channels or volume
Is the remote a universal? Make sure you select TV as the the device you are trying to control. You can also fix a wonky remote by popping out the batteries and mashing down all the buttons. This rids the remote of any built up electricity that could be hampering functionality. Also, the remote sensor on the TV is controlled internally of course so a power drain of the TV wouldn't hurt:
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
What do the buttons on the TV itself do? Do they work properly? If not, the problem is going hand-in-hand with the remote and again, the problem is internal and service or a firmware update, if available, may resolve this.
Sep 20, 2008 | LG 42LG50 42 in. LCD HDTV
DVD player locked
I had this problem too. I found this solutiong on another web site and it worked. To unlock the dvd player turn on the tv.Get your remote in hand. Press and hold the stop button for the dvd player on the TV/DVD/VCR. Now press the power button on the REMOTE. This will unlock/lock the dvd player.
Mar 17, 2008 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Philips universal codes
If you dont have the codes for a philips universal remote you have to press code search and TV at the same time till the led light stays on. Then press the power button a few times untill the power turns your TV off, then press the OK button. After that the code should be in the remote.
Dec 07, 2007 | Philips Magnavox Learning Universal Remote
Tv vcr combo cannot program tv
Try pushing the volume buttons in the middle so that you are mashing both the up and down button, your menu should appear. then you can use the channel buttons for moving up and down.
Dec 02, 2007 | Emerson EWC1902 19 in. TV/VCR Combo
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
