Question about Bamix De Luxe Hand Mixer
I need to replace the diode in the speed control of my Bamix M122 but I can't see any markings on the diode to help in buying the correct replacement. Does anyone know what a suitable replacement one might be identified as?
  • 276 Answers
Hi. When repairing these we use an IN5404 diode.
The original is 1N4004 which is a lower voltage rating.
Either will do.
Posted on May 26, 2010
Testimonial: "Brilliant - exactly what I needed to know!"
Shaft does not rotate motor workink
My Bamix stopped working--no shaft movement and loud motor noise (think disuse caused motor lubricant to thicken). Propped it upside down and put drops of quality machine oil at seam where narrow blade shaft enters larger shaft (in center of curved guard). Probably not necessary, but added a few drops where large shaft enters handle. Oil slowly seeps in. Attached a blade to manually turn for oil distribution. Did this periodically over several hrs. Turned on low speed and it gradually returned to full speed capacity.
Oct 25, 2013 | Bamix De Luxe Hand Mixer
KitchenAid k5a arcing on control board
it was stuck on high speed because the phase control board went out, your fix may not be absolutely 100% and it is now causing an uneven distribution of the electric charge in the mixer and it is arching. My recommendation is to replace the speed control board (black and copper plate) and the phase control board. i bet it fixes the problem as these are the two parts that regulate the electricity in the mixer. Hope that helps. Buy the way if you don't fix the problem and continue to use the mixer you may have to replace the motor eventually as you can cause the armature and stator to short or burn out.
Feb 03, 2013 | KitchenAid K5ADH 5 Quart Mixer Dough Hook...
My bamix attachments keep falling off, tried tightning them as per instruction book to no avail.
II had the same problem but I just kept adjusting it and make sure it fits into the notch, and it works. It a bit annoying, but persevere.
Best wishes
Jan 15, 2012 | Bamix De Luxe Hand Mixer
How do you remove flange on bamix m122
Bottom flange has a left hand thread which you can undo by hand. Then the small dowel pin can be removed with a good set of pliers.
May 30, 2010 | Food Mixers
Where do I get new blades for my Household Blending Mixer HA-3058
It seems you can no longer buy the MegaMixa HA-3058 however Bamix sell a similar product - in fact apart from a couple of aesthetic modifications it seems to be the same machine....
They sell many accessories and you can get blades. Check:
www.bamix.com
www.bamix-blender.co.uk
I have both machines and the blades are identical and inter-changeable between models.
Feb 23, 2009 | Food Mixers
I have lost the mincer attachment to my wand - almost 25 years old now and still going strong. HOw much to replace and post this part please.
goto:
http://www.google.com/search?hl=en&client=firefox-a&channel=s&rls=org.mozilla%3Aen-US%3Aofficial&hs=L6q&q=bamix+accessories&btnG=Search
and choose products from your favorite vendor.
Nov 08, 2008 | Bamix De Luxe Hand Mixer
Basic mayonnaise
I have had that problem more then once.
You have to make sure your egg, oil,lemon, vinegar
are at room temperature. You will be very happy when it works. It is fabulous!
Good Luck.
Oct 13, 2008 | Bamix De Luxe Hand Mixer
Bamix slowdown - repair service anywhere out there?
click on the "contact" link in this website http://www.bamix-usa.com/ there's places in Canada & the US to have them serviced. Through contacting them they'll give you the nearest service area.
Good luck, love my Bamix!
Aug 11, 2008 | Bamix De Luxe Hand Mixer
Attachments fall off
Excerpt from: http://www.bamix-usa.com/
It can happen that the attachments fall off the shaft as they have in time become loose. In this case simply press the spring blades lightly together with a pair of pliers
Feb 23, 2008 | Bamix De Luxe Hand Mixer
Bamix De Luxe Hand Mixer Logo
612 people viewed this question
Top Bamix Food Mixers Experts
eyecam
Are you a Bamix Food Mixer Expert? Answer questions, earn points and help others
