Question about Black & Decker Black Decker 400 Watt Power Inverter Pi400abozr
Trying to run a digital projector from a car battery
Bought a black and decker 400w power inverter, tried to plug into the cigarette lighter, it was unable to run the projector. the red light goes on as soon as i press power. The manual says i should try to clip it directly into the car battery terminals, i want to ask if this will work for this projector: http://www.projectorcentral.com/Epson-EX31.htm
it was a wet night and thought i should ask someone before i go fiddling around with battery terminals in mild wet conditions. also, i'm trying to run a 100' extension cord from the inverter, will the length of the cord affect the ability to conduct current? thank you
-j
  • 843 Answers
I looked at the power requirements of this projector, 280W, but that assumes a nice sine wave. Your inverted is supposed to put out 400W, but it's a modified sine wave. Under ideal conditions (including a good battery) this might be just enough. Connecting directly to the battery will help a little, because of the limited ability to get current to and through the cigarette lighter. Using a 100 foot extension cord will diminish the voltage a bit (less so if it's a heavy gage wire). I would try connecting the inverter directly to the battery, run the engine and skip the extension cord. If that works, turn off the engine. If that works, try the extension cord. If it won't work with the engine running, connected directly and no cord - there are two possibilities: (1) the projector just won't run on a modified sine wave, (2) you need a bigger inverter. --- regarding (1) I have seen lots of people having trouble with various devices. You might want to ask Epson support. --- Good luck!
Posted on May 26, 2010
I bought a Nexxtech 175 watt inverter to power my laptop. It worked fine in my truck in the store parking lot but won't work in my tractor where I really need it. It works from the power point or the...
It could be any of a number of things, but the first 2 guesses I am going to make are:
1) The contacts in the cigarette lighter jack in the tractor are corroded; or
2) the wires that power the cigarette lighter jack in the tractor are too small of a gauge to provide enough current flow without a voltage drop. This one can be tested by popping the cigarette lighter jack out of the dashboard while still wired (carefully, you don't want to cause a short-circuit), and then plugging in the inverter and measuring the voltage with a multimeter going INTO the lighter jack. It should be at least 11.5, preferably 12, Volts. Test both before and after the inverter is plugged in. If the after reading drops too much, then you know you need a bigger gauge wire feeding the lighter jack.
May 06, 2014 | NexxTech 175W Power Inverter
I bought a new Black and Decker 200 watt power invertor to plug into our car cigarette lighter to power a laptop. We did this and our car blew a fuse. We went to Saturn to fix it and they could not...
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Aug 23, 2010 | Black & Decker Electronics - Others
Hi i have a 400w black and decker inverter as soon as i plug my lap top in to it the power light on the inverter flashs and it wont power my laptop
The output of this inverter (and most others) is a modified sine wave, which isn't quite the same as a true sine wave - like you get from a wall outlet. Unfortunately, most transformers (which is essentially what your laptop power-supply is) require a true sine-wave. Your inverter will work fine for many other 110V applications. You can buy an inverter with a true sine-wave output, but they are more expensive.
Aug 19, 2010 | Black & Decker Power Inverter PI400AB
I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
Jul 15, 2010 | Black & Decker Power Inverter PI400AB
How do you change the fuse?
Most devices like this have the fuse inside the plug that goes into the cigarette lighter. The knurled silver tip unscrews. Caution that you don't loose the spring inside.
May 19, 2010 | Black & Decker Black Decker PI100AB 100...
400W Black & Decker Power Inverter Doesn't Power My LCD TV
The problem of your inverter is from
your battery .your laptop and dvd
player requires little current to
operate.But you tv requires more power
to run, if your battery is low you it will
not last for 3 minutes. If your battery
has a low current rating, it will also be a
cause, for example, if it is below
100ampere hour. Lastly if your battery
is bad i.e. if it reads below the
stipulated dc voltage Require by your
inverter to operate.
May 09, 2010 | Black & Decker Power Inverter PI400AB
Black & Decker P1400AB fuse change
If it is the fuse inside the cigarette lighter plug, just unscrew it and put a new fuse in.
If you mean replacing the two 25amp fuses inside the inverter housing, you can bypass the fuses by soldering the two sides together. Or, if you want to put new fuses in, heat the solder holding the fuses in until they pop out and insert new ones.
As for opening the housing, good luck!! I ended up using steel cutters to rip off the plastic. The best option would be to buy a new one and return the old one in the package.
Jan 16, 2010 | Black & Decker PI400AB Power Inverter
Why does the power inverter keep beeping when i plug up my laptop
If your not getting enough voltage to the inverter it will beep to let you know you don't have enough power. Most common cause is a lose connection thru your cigarette lighter. Also if you turn your key off it might be shutting down power to your plug.
Make sure you have a good connection with your battery or plug adapter. You also need a good battery so you don't go into a low voltage condition which will make your inverter beep.
Oct 29, 2009 | Black & Decker Power Inverter PI400AB
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Power hook up
This type of inverter has large alligator clips on it because the amperage that comes through a cigarette lighter is insufficient and can result in blown fuses and overheating of the socket. Hook this one up directly to the battery without splicing a longer wire to it.
Apr 22, 2009 | Black & Decker Husky 750w Power Inverter
Black & Decker Black  Decker 400 Watt Power Inverter  Pi400abozr Logo
789 people viewed this question
Top Black & Decker Electronics - Others Experts
Craig Butler
Craig Butler
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
