Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Vacuum extremely noisy
My bissell power force bagless vacuum became extremely loud.If The beater bar is out it is fine but as soon as I put the bar in it sounds like a train or something.Anyone have any advice
Mine is doing the same thing and my husband told me to purchase a new beater bar. I suggest you do the same.
Posted on Jan 21, 2011
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
Free instruction manual for bissell 4104
I've found step by step video demonstrations for cleaning, belt replacement, basically maintenance of different appliances on "YOUTUBE" you might want to check it out. Just type in Bissell 4104 beater bar replacement. Hopefully there will be a video showing you exactly how to replace it properly.
Jan 04, 2012 | Bissell 4104 Bagless Upright Cyclonic...
Beater bar is not coming on- belt is on, canister is empty. Vacuum runs but no beater bar
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Mar 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Bissell powerforce bagless extremely loud.
It could be that the belt is worn. You can get replacement belts and the manual here:
Bissell PowerFrorce Belts and Manual
Nov 21, 2009 | Bissell 6594 PowerForce Bagless Upright...
Belt
Hi. This isn't a hard repair at all.... Unplug your vacuum. Turn the vacuum beater bar side up. Locate the catches or screws that hold the plate on that covers the beater bar. Remove the plate. The beater bar sits in sockets where it attaches to the vacuum, so remove carefully, making note how it comes out. This will make reassembly much easier. Place your new belt on the motor shaft, then onto the beater bar while you replace the beater bar back into the sockets. Test your work by revolving the beater bar a bit by hand. Reinstall the cover plate. That's it!
Regards! --W/D--
Jul 17, 2009 | Bissell 6594 PowerForce Bagless Upright...
Power bar makes loud groweling sound when turning?
Ours has been doing the same thing...the beater bar end plates, black thins, and the little groove area they go into are worn of the front and rear surfaces. You could buy a new beater bar but the wear on the housing would require quite a bit of work to replace that hole piece.
You will also notice that the belt is loose due to this wear.
Solution....duct tape to the rescue!
I took out the beater bar and took a strip of duct tape about 1-1½ inches long and folded that over to be a long narrow pad that fits in the groove that the beater bars end plate slides into...the groove to the rear of the beater bar.
Then I took a piece of duct tape and taped the little pad/shim I made to the rear edge of the beater bar so the pad will be in the groove when the bar is installed.
Put the bar back in carefully and no more noise and the belt is now tight again.
The fact that these 2 parts wear on each other and this affects the tension of the belt is what causes the noise...the sloppy belt will get so bad it will start jumping over the teeth and soon after it will break.
My wife was impressed...hope it works for you too...
Would make sense to make a more permanent solution but I just did this a couple days ago and we have vacuum the whole 2500 sq. ft. house with no extra noise...I have time to figure out better...maybe a harder plastic cut to fit in there...
Apr 25, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Brush will not turn
Possible Solution: I had the same problem with my Powerforce vacuum. Please take note that I AM NOT a vacuum cleaner repairman, nor have I played one on TV. Try taking your beater bar out, and if it looks similar to the one pictured (Model#203-1195), get a cresent wrench. Look at the end of the beater bar one will be squared on the sides to hold the shaft inside statonary. Take the wrench and adjust it to fit the nub on that end. Grab the bar in the center, and turn the end with the wrench. Mine popped and came loose, then it could be turned by hand. A little light oil allowed to run into the end cap, turn it up and spin it a few times to let the oil work down the inside and put it back on. Mine works fine for now. Good Luck!!
Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
Beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
542 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
