Question about General Heating & Cooling
Can't get my oil column heater to work. Goldair GOC311. No power light when on the high or low settings. No heat. ? Stuck
2 Suggested Answers
  • 146 Answers
SOURCE: Hi, I have a Goldair oil column heater which is a
im sure it has a fuse-able link that will melt when the temp gets to high. it is a safety option
Posted on Jun 05, 2010
Reset a Honeywell HZ-709 portable electric oil room heater?
I'm going to ask the first "obvious" question: are you sure the socket you're plugging into is delivering power? (Sorry to ask but it's an Occam's Razor kind of situation) Have you tried a different socket in the same room? Next, does the main power switch for the heater have different settings i.e. high, medium, low, high-high, high-low, low-low and have you tried those combinations? Next, pick up the heater (if it won't hurt your back) and give it a robust shake. Try the power again. Any luck? Keep us posted.
Mar 06, 2015 | Honeywell HZ-709 Oil Filled Radiator...
High beams do not work
I had this issue as well. My headlights did work but the high beams didn't. I replaced the high low beam switch under the dash bolted to the steering column. Go to rockauto.com and it'll be under your vehicle under electrical switches. The switch heats up and gets stuck in high or low. Common problem. Good luck!
Dec 13, 2014 | 1998 GMC Suburban
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
Is it OK to set fan speed control to Low?
you can turn this too low but the heat exchanger will get hot and you will have less air coming out of the vents it should be set to makes spec . gas fed to burners has nothing to do with fan speed ,have you oiled the fan motor
May 08, 2012 | Heating & Cooling
Jun 05, 2010 | Heating & Cooling
Efficency with Oil Column heating
because it operates on room air temperature, if this is the only means of heat to this room, leaving it on would be more economical thus keeping the rise in air temp time less=less time it works hard to match what you desire. but if not only source of heat no. time to heat room would be almost the same thus you would save what you used during the day due to fluctuations in room temps between time your furnace would kick on and off.
Jun 08, 2008 | DeLonghi 6507L Oil Filled Radiator Heater
Bionaire BH3950 Does not heat
I'm not an expert, but I have two of these units that are working fine.
The on/off switch (the top switch) has a light in it that illuminates when the heater is on and heating. If this light comes on and there is no heat, then the element is probably burned out.
The heater has a safety switch that prevents the unit from working if it is not upright. If the heater was stored for any length of time on its side, the safety switch might have stuck in the off position. Unplug the heater and with the heater upright, try shaking it or slapping it firmly with your hand to se if this fixes the problem.
If none of this works, then as sunmasc says, the thermostat is bad.
Jan 12, 2008 | Bionaire BH3900-U Oil Filled Radiator...
Heating & Cooling Logo
105 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
