Question about SanDisk Sansa e250 MP3 Player
Problem in my mp3 player
I'm having sandisk e250.First it was working properly.But one day,full charge was discharged.It is not recharging.What has to be done
  • Anonymous Apr 08, 2008
    My e260 became fully discharged and will not recharge on the USB computer connection. How do I recharge it?
  • 8,596 Answers
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Posted on Apr 08, 2008
Change battery sansa ciip
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 13, 2013 | SanDisk Sansa Clip MP3 Player
Battery not holding charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 26, 2013 | SanDisk Sansa e250 MP3 Player
My sansa won't turn on...the battery was full and everything..I have tried charging it...do I have to get a new one or can it be fixed?
I'd get a new one - the rechargeable battery is probably bad. It'll probably cost as much to replace the battery than getting a new unit. These MP3 players are reasonably priced nowadays.
Dec 21, 2010 | SanDisk Sansa e250 MP3 Player
How can i recharge the bttery of my sandisk?
well u should have a usb connection plug on ur pc and charge i reccomend a usb wall charger
Jan 04, 2010 | SanDisk Sansa e250 MP3 Player
Did not receive manual. How do you recharge
Simply attach the USB plug that came with the device to your MP3 Player, then plug the other end into a computer, it should automatically start charging! A full charge usually takes about 2 hours.
Hope this helps!
Dec 25, 2009 | SanDisk Sansa e250 MP3 Player
SANA E250 NOT WORKING
The problem may be from these two things (1) The power IC must have been damaged by the current supply (2) The Flex of the phone may be bad. Try to make sure that the battery of the phone is not discharged too, try to power it again and if it doesnt get on then the power IC of the phone is burnt.
Sep 17, 2009 | SanDisk Sansa e250 MP3 Player
Batter low shutting down
Your battery is low, therefore the player is shutting down.
Recharge the player by plugging it into your computer for 3-4 hours - make sure the hold/lock is not activated, or it will prevent proper charging.
-Tha Mp3 Doctor
Mar 18, 2009 | SanDisk Sansa e250 MP3 Player
My sansa e250 won't charge
I had the same problem - the player needs to be unlocked (the little switch on top) to be able to charge - pretty stupid if you ask me but what can you do
Jan 09, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Battery Low always when charged fully
is it connected properly?there should be a green line going back & forth on a "battery" if the battery is no good,theyre cheap on Ebay.Make sure its new,check shipping costs as they vary.Open up the back-4 screws.Lift out battery.FULLY recharge.Very easy.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
Prombles Recharging Battery
Try upgrading the firmware of the player. If it still discharges quickly it may be the battery contact POP and have the battery replaced.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
24 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
