Question about RCA HD50LPW42 50" Rear Projection HDTV
I have a DLP HD50LPW175. I replaced the color wheel but now the faces of people are blue.
  • kmanning46 May 27, 2010
    Hi ladywinn,
    I don't think the light engine optical assembly is the problem. The colors were perfect with the original color wheel. I ran into this same problem with a Samsung HL-P5063. With the original color wheel, the colors were perfect until it was replaced with a new one. When it was replaced, the faces were blue. The problem was that the original color wheel was different from the new one. The original uses an air bearing type motor but the new ones is a standard bushing type. To correct the problem, you re-position the jumpers on the DMD board but I haven't been able to find it. I don't know if the RCA uses the same procedure or not. I still cannot find the jumpers. Since the orginal color wheel showed a perfect color and white balance, I don't think the optical light engine is the problem. If the light engine is the problem, the colors should be off with the original colorwheel.
  • RCA Master
  • 5,138 Answers
Bad light engine/optical assy Call UED 1-800-648-6657 or try Encompass Parts Distribution 1-800-638-3328
Posted on May 26, 2010
All the lights are blinking
If a DLP suspect first the lamp, then the color wheel, which are the two most common failure parts in this set.
Color wheel faces lamp--look to see lamp not shattered inside and color wheel not missing parts of the plastic wheel at the same time as lamp is removed--it faces the lamp.
Jun 01, 2012 | Samsung 50" Slim-Depth DLP HDTV
RCA DLP
have you adjusted your convergence settings?
if not please do that
Aug 03, 2008 | RCA HD50LPW175 50" HDTV
I have replaced a color wheel for a DLP Samsung TV but some colors does not appear making every face turned blue with less definition
Hello luis_crocchi,
Welcome, and thank you for using FixYa!
To answer your question: You have replaced the color wheel, but the light engine (jet) will probably need to be replaced also.
You will also have to have the color wheel and jet tuned (timed) back to factory specs by a TV Repairman as well. If timing and lighting are out of sync, the picture will be also.
Have a great day!
Sep 12, 2011 | Televison & Video
Replaced the color wheel on a Samsung DLP
Did you replace the color wheel yourself ? Sometimes you have to remove a small black jumper on the DM module on the light engine and that will remove the greenish but sometimes adjustments also need to be made in the service menu.
Oct 30, 2009 | Samsung HL-R4667W Rear Projection...
I have a 50 inch RCA Real Projection TV (DLP or HDTV). I just replaced the lamp and everything worked fine. One night it made a big sound and shut off. Now when you turn it on, nothing appears, a few...
you could have a color wheel problem or a power supply problem
one questions did you reinstal the door at the rear
you might want to remove the lamp module and try a reinstal and see if condition changes
as to costs if you can get the color wheel 150.00 or so
there ae several things that could cause this a dmd module a color wheel and power supply or digital board the lamp cover when installed it closes a saftey switch there thats why i ask if you has installed door
Oct 22, 2009 | RCA HD50LPW175 50" HDTV
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Color is wrong after color wheel replacement
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Jan 22, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Rcatv
I have found that this color wheel comes with a set of instructions that includes getting into the service menu and setting the index for the new color wheel. If the instructions were not with the color wheel, you will need the DVD for this model to find the information on entering the service menu and setting up the color wheel.
Jan 04, 2008 | RCA HD50LPW175 50" HDTV
RCA HD50LPW42 50" Rear Projection HDTV Logo
227 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
