Question about Sharp WideNote M4000
Sharp M4000 fan problem
I have used my sharp M4000 for 2 years, but couple days ago the cooling fan has some irregular noise especially when it is in low speed, it seems something stuck inside to prevent it to run smoothly. Anyone know what's the problem is? thanks.
    Guru:
  • 1,342 Answers
Fans will collect dust and dirt over time and should be cleaned out occasionally with compressed air.
Posted on Apr 07, 2008
How do I find sharp's PC-M4000 contol drivers there website non existant
You can try this link.Most "Sharp models" make their boards with similar drivers,so try downloading one of the drivers from the link first and see if it works http://www.driversdown.com/driverslist/s_631_1.shtml
Apr 13, 2010 | Sharp WideNote M4000
Replacing the DC input connector on a Sharp m4000 widenote laptop
Yes it can be replaced and it has to be done with experience in soldering desoldering or the mobo will be junk. Splitting the cases is only a small part of the job if you have no experience in soldering methods. See if there is another way that you can charge the battery but I can not imagine it to be convienent
Jul 30, 2009 | Computers & Internet
Fan in our Sharp "Comfort Touch thru-wall a/c stopped
Unless the Unit can be cleaned ( you claim it cools?) but not enough. The age of the Unit is not in you Question, the amount of time you got for 100 bucks is pretty good being you purchased a USED UNIT. With the type of use you claim Running 24/7 and about 5 months of cooling - I'd say you never cleaned the Unit from day one - that might cost you about 100 bucks if the unit can be done in the yard by a serviceman. Chemicals can hurt the Unit if not done properly ( and yourself). It sounds to me like you use it for a Business - if so you can purchase one and write it off .
Jul 18, 2009 | Sharp AFR120NX Thru-Wall/Window Air...
After 20 minutes of use picture shuts down. (Sharp XR-10X)
use canned air and blow every bit of dust out of every vent and hole. if you want to, you can remove the top (6 screws on the bottom, and the 2 top screws on the back) and blow dust out that way. i could also be a power supply problem. from excessive heat, the capacitors on the ps dry up and don't work as they should, causing shutdown.
May 24, 2009 | Sharp XR-10X Multimedia Projector
Sharp xr10x whining noise affects color sometimes not fan.
gas+heat=boom. learned that lesson myself.
sharp part # PFiLWA087WJZZ (c/w assy.)
remove the top (6 bottom screws, 4 back screws (not the one near the plug)). facing the front of the projector, the colorwheel is behind the front leveler foot and attached to the orange ribbon cable. you need to remove the lamp housing, the main board, the fan assembly between the lens and the power supply, and the lens assembly (optical engine). now remove the 2 silver screws holding the colorwheel assembly to the optical engine. that part number is for the wheel itself, so remove the 3 small screws to get it off. to install, repeat procedure. keep in mind which screws and which cables go where.
Apr 06, 2009 | Sharp XR-10X Multimedia Projector
Keyboard of a sharp pc-m4000
u can not replace it it will not work
just change keypad or use external kaypad
Jan 22, 2009 | Sharp WideNote M4000
Projector shuts off sporadically
1. Pls check the airflow of the cooling of the projector, or just service the all unit.
2. As you told that the lamp life is 76%, Check the inner
reflector have shiny surface of dimmy, If not shiny, then replace
the lamp unit.
Enjoy
Viren
Jul 20, 2008 | Sharp XR-10X Multimedia Projector
need to replace the lamp. i could have diminished not as much to frequent on and offs, but excessive dust. it's heating up too much and shutting down.
May 31, 2008 | Sharp XR-10X Multimedia Projector
Sharp WideNote M4000 Logo
143 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
