Question about Sony VPL-EX1 Multimedia Projector
When i turn it on the bulb (which is new) doesn't come on
  • 821 Answers
Hello,it is either it is not well fixed,i will advice you replace the lamp.you can kindly visit the link below to see how to fix the lamp,
http://www.youtube.com/watch?v=9-A154ZVz0I
take care.
Posted on May 26, 2010
Turn signal doesn't work
Remove old light bulb. Clean all contacts, put some die-electric grease on the new bulb, reinstall. Since I did that to my Intrigue I haven't any problems with bulbs blowing. I think it's a problem with moisture getting inside and the grease stops the bulb from shorting out.
Apr 20, 2013 | 2000 Oldsmobile Intrigue
2004 Honda Pilot, right rear brake light doesn`t work. I know it`s not the light bulb because it works for the turn signal and hazard lights.
Chances are that is the bulb. Its a dual filament bulb. The brake portion of it is burnt out. try swapping it with the left side and see if it works then. If it works, get a new bulb.
Apr 17, 2013 | 2004 Honda Pilot
Turns on but doesn't do anything else. Screen doesn't come on. Can hear a clicking sounds like a turn signal sound.
looks like a( DLP) tv digital light proccessor . aka projection. most likely the bulb is burned out . if so cost is $65-125 bucks. aftermarket bulbs are available online but some dont work or burn out prematurely. if you decide to fix it or buy a new tv ,invest in a surge protector. it will save your tv from problems like this . good luck.
Feb 11, 2013 | Televison & Video
Tail light is not lighting up in my 2000 ford expedition
brake and turn are the same filament in the bulb. Try a new bulb. if that doesn't work your going to chase a short/ground on that wire back to the switch. get a wiring diagram to help.
Aug 05, 2012 | 2000 Ford Expedition
Freezer light does not come on when open have to jiggle swtch
Unplug the refrigerator and turn the bulb counterclockwise to remove it if the light still does not work. Insert the bulb back in the socket and turn it clockwise to tighten it. Plug the refrigerator in and reset the controls.
If the light still doesn't work, turn the control to the "Off" position and unplug the refrigerator. Remove the bulb and purchase an appliance bulb with the correct wattage. Insert the new bulb and turn it clockwise to tighten it. Plug the refrigerator in and turn the control away from the "Off" position.
Read more on User Guide for LG LFD22860 page 26 and 27.
Hope this helps and just keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Nov 03, 2011 | LG Refrigerators
How to replace interior dome light bulb?
1) Remove the key from the ignition. Make sure the doors are closed, so the new bulb does not illuminate when you are installing it.
2) Make sure the dome light switch is turned to the "Off" position. Pry the plastic lens away from the dome light. Use a small, flat-head screwdriver.
3) Push back the side bulb clamp. Pull out the old dome lightbulb. Wipe the area with a paper towel if it is dirty.
4) Wrap the new bulb in a paper towel (oil from your skin will shorten its life). Insert it into the dome lightbulb holder. Push it up gently to secure it.
5) Turn the switch to "On" to test the bulb. Reposition the cover and push up to lock the clips into place.
If the bulb doesn't work, you've got a bad switch somewhere, probably on the drivers door.
Dec 26, 2010 | 2006 Toyota Highlander
Oven light bulb
It just turns counterclockwise to come off. Sometimes it is very hard to turn them. If you have a strap wrench you could try that.
Nov 04, 2007 | GE Spectra JGBP35 Gas Kitchen Range
Sony VPL-EX1 Multimedia Projector Logo
35 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
