Question about Mirra M-160 (M020160) Server
Where can I purchase a new power supply for my Mirra M-160
  • mail96 Jun 01, 2010
    If you find out let me know please, my Mirra M-160 just stopped a few days ago and I think it is power supply as have volts going to it but does not turn on.
    thanks
    mail@jbewing.net
Go to http://www.suntekpc.com/
I found this for my unit. http://www.suntekpc.com/htm-2/power-supply-ps-flex-81x-flex-atx-fan-blow-out.htm
FLEX ATX Switching Power Supply
FSP150-50PL (FSP150-50PL-B Flex ATX)
WxHxL: 3.2x1.6x6-inch (81.5x40.5x150mm)
PS-FLX-FSP150-50PL
I sent email to simon@suntekpc.com for pricing and sure way to see if power supply is out.
Posted on Jun 01, 2010
NO power
That problem is usually have 2 causes..Its either power supply board or main board..
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Thanks for using fixya...
Sep 24, 2012 | Televison & Video
M120 will not power up - no lights, nothing
The Geek Squad at Bestbuy can do this. They are rather pricy though.
Jun 26, 2008 | Mirra M-120 (MIRRAPERSONALSERVERM120)
Tip
IRobot Mirra 530 Setup
Setting up your Mirra 530 is easy!
  1. Use the power supply at least 12 feet from the pool
  2. Plug the cable into the power supply
  3. Place your Mirra in the pool, rocking it side to side to release air
  4. Once Mirra has sunk to the bottom, plug in the power cord into a grounded outlet
  5. Press the "Clean" Button on the power supply.
Mirra will start the cleaning cycle!
on Sep 17, 2013 | iRobot Mirra 530
Tip
Example: How to change your mp3 player background
Follow these steps to clean and maintain your Mirra for the longest life possible.
1. Ensure the Mirra is disconnected from the power-supply9_17_2013_4_42_42_pm.jpg
2. Rinse the filter as shown in the image below after each cleaning cycle.
You can also view a video here: http://www.fixya.com/tippage.aspx?thid=20133874&mt_f=tip_capture
3. Clean the scrubbing (roller) brush by removing any debris that might be wrapped around it.
  • Position Mirra upright (fig. 1 below), so you can view the scrubbing brush
  • Push the end cap of the brush inward, using a screwdriver, and pull out the roller (fig. 2 below)
  • Place the newly cleaned brush in the Mirra, snapping the end cap into place until it clicks (fig. 4 below)
4. Check the propeller as follows. REMINDER: BE SURE THE POWER-SUPPLY IS DISCONNECTED FROM THE MIRRA BEFORE CHECKING THE PROPELLER
  • Remove the filters from the Mirra (fig. 1 & 2 below), if not removed already.
  • Unscrew the propeller top cover using a Phillips head screwdriver, counterclockwise (fig. 3 below).
  • Remove the cover (fig. 4 & 5 below)
  • Remove any debris from the propeller (fig. 7 below). Note: there is no need to clean out the pump motor.
  • Place the propeller top cover back onto the robot (fig. 8 below)
  • Screw the cover back into place, by screwing the screw in clockwise (fig. 9 below)
5. Straighten out the floating power cord periodically, so it doesn't develop kinks over time.
Information acquired from iRobot Solutions
Tv schematic for samsung tv
Jun 06, 2012 | Televison & Video
TV will not power up when plugged in. i hear a clicking noise near the power supply.
Jun 06, 2012 | Sony BRAVIA KDL-52S5100 52 in. LCD HDTV
Tip
Power Supply Issues: Your Troubleshooting Guide
If the power supply shuts off unexpectedly or doesn't turn on at all, try the following steps:
  1. Check that the power supply is connected to a grounded, 3 conductor socket.
  2. Check to see if the outlet has power, by plugging another device that works in another outlet.
  3. Check the power supply cord to ensure it's not damaged.
  4. Place the power supply (transformer) at least 3.6 meters / 11.8 feet from the pool and at least 12 cm / 4 Inch above the surface (fig.1). The transformer will supply low voltage to the cleaner
  5. Uncoil the cable (fig.2)
  6. Place the unit in the water. Turn the unit side to side in the water to allow air to escape from the body and then let the cleaner sink to the bottom of the pool (fig.3). Allow wheels to soak for 15 minutes before using Mirra for the first time of the season.
  7. Then, spread the cable over the surface of the pool as evenly as possible (fig.1).
  8. Plug the cable into the power supply. Make sure the key on the plug corresponds exactly with the key slot on the socket of the power supply (fig. 4a)
  9. Plug the power supply into a grounded outlet. (fig. 4b)
  10. Press the CLEAN button and the light will glow indicating that the system is "ON." The pool cleaner should start the cleaning cycle (fig. 5). Turn the power supply on and off a few times, leaving 45 seconds in between each action, if the pool doesn't start cleaning.
  11. If problem still continues, please contact customer service or your local repair center for further assistance.
Information acquired from iRobot Support
Tip
IRobot Mirra 530 Tips & Tricks
Tips from iRobot Resources:
Run Mirra only when in the water.
Mirra has a very strong motor system that needs to stay cool for optimal performance and life. Your pool water around the motor helps keep it cool during operation. Therefore Mirra should not be run outside of the pool due to the risk of overheating the motor.
Choose the correct filter canister.
Use the Large Debris Filter Canisters when the pool contains a significant amount of large debris (leaves, insects, etc.) and when the pool is opened for the season or cleaning during the Fall. The Fine Filter Canisters are ideal for filtering small debris such as algae, sand, silt and bacteria and for regular pool cleaning maintenance during the peak of your pool season.
Keep Mirra working at peak performance.
Mirra uses the powerful force of water pumped through its filter to clean and circulate pool water and to propel itself around your pool. It pumps and filters more than a gallon of water every second! Clean the filter canisters regularly by removing them from Mirra, emptying its contents and hosing it out. Keeping the filter canisters clean will ensure optimal cleaning results and strong pump suction.
Allow the motor to cool before removing the robot from the pool.
Mirra's power supply has an automatic timer that shuts Mirra off after each cleaning cycle. Wait 20 minutes before removing Mirra from the pool to allow the pump motor to cool. Turn the power supply off and unplug it from the electrical outlet before removing Mirra from the pool.
Turns off by itself
Hi you can connect another additional totally empty HDD to your computer and boot thru one of the disk manager cd - its GUI based , under maintenance option it is possible to copy entire contents of existing HDD into the empty HDD you connected .If can see too much of dust accumulation then you consider the fan to be malfunctioning component else there exists a short circuit in other components.
Apr 14, 2008 | Mirra M-250 Server
Mirra M-160 (M020160) Server Logo
175 people viewed this question
Top Mirra Computers & Internet Experts
David Payne
David Payne
Are you a Mirra Computer and Internet Expert? Answer questions, earn points and help others
