Question about Samsung WEP170 Wireless Headset
I cannot pair the headset with my new iphone - Samsung WEP170 Wireless Headset
  • 185 Answers
Go to the menu on your phone select manage connections set up bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
If it works for you, don't forget to rate me
thx
Posted on May 26, 2010
  • 821 Answers
Hello,it is either they are not compatible,is the bluetooth headset a universal one,if not it will not pair with the iphone.kindly check if the bluetooth is being powered on well and also make sure both the iphone and the bluetooth headset are well charged.
please kindly rate the solution if it's helpful,
take care.
5 Suggested Answers
bob_computer
  • 3153 Answers
SOURCE: cannot pair my Emerson EM-227 wireless headset with my Iphone
Some headsets have a built in code not all are 0000 check your documentaion for both the phone and headset
Posted on Aug 08, 2009
SOURCE: Trying to pair my Motorola Headset H681 with my
the pass key is 0000
Posted on Jan 01, 2010
SOURCE: pairing my Z9i v1.1 headset with my new iPhone
I had a problem with this also, try this.
Turn off both devices then turn on your phone.
make sure your bluetooth option is "ON" on your phone
turn on the blueant z9i
press and hold both volume buttons, while doing that, press the ANT button.
Your blueant should be flashing fast right now and your iphone should be able to find it.
complete the pairing by selecting the blueant headset on your iphone and enter the code "0000"
enjoy
Posted on Feb 01, 2010
EdNelson
  • 149 Answers
SOURCE: my uniden bt108 bluetooth headset would not pair
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Posted on Jan 04, 2011
How do I pair my iPad as the second device
Make sure that the headset is not paired with the iPhone (turn off Bluetooth on your iPhone temporarily). Follow the same procedure you used to pair the iPhone, but this time with your iPad.
Dec 26, 2014 | Radio Communications
It cannot connect with mobile phone, I tried to use HTC and IPHONE to connect, all of these cannot search the signal from bluetooth? why? I also tried to turn on and off mobile phone and bluetooth for many...
Here is something to try on your iPhone. Hopefully it should fix your problem.
On the iphone, delete all the headsets you may have used from the UI of the iphone.
Turn off the headset.
Warm reset the iphone, press and hold the home and power keys on the iphone for 10s, the screen will go blank and the phone will reset.
While the iphone is rebooting, turn on the headset again and put it into pairing mode with the LED flashing red/white, red/white ...
Now when the iphone is ready, make it search for the headset.
When you see the "9xxPlantronics - Not Paired" entry on the iphone UI, then tap the screen where this message is displayed and the iphone will pair to the headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 22, 2011 | Plantronics Discovery 975 (8164001 P)...
When I first bought the product I had no problem pairing it with my 16 gig iPhone. Since replacing that phone with the 32 gig iPhone I have been unable to pair the plantronics K100 with my new phone. Why...
One possibility: If your new phone is paired but not connected because the K100 is looking for the old phone. When powering on the K100 it searches for the last connected cell phone. If the last connected phone is not within range, or the Bluetooth feature is turned off on the phone (which hopefully the first iPhone is turned off or at least out of range), then another phone within range that has been previously paired with the speakerphone can be connected by tapping the Multi-function button.
For additional help, Plantronics K100 Users Guide
Good Luck from Headsets Direct!
Jun 14, 2011 | Plantronics K100 Bluetooth Headset
Need instructions for connecting ear piece to iphone 4
Hi,to complete the look of a tech-savvy, iPhone-using individual, you must have a Bluetooth headset to accompany it. You can pair any Bluetooth headset with an iPhone. The Motorola HS850 is no exception to this. Both Motorola and Apple's Bluetooth set-up process is fast, so you'll be talking with people through your new Bluetooth on your iPhone in a matter of minutes.
Instructions
Charge the Motorola HS850 headset fully before attempting to pair. Usually, it takes two to three hours to charge the headset.
Press and hold the "Call" button (has a phone icon on it) on the headset for six to 10 seconds. The outside LED light will turn on indicating that the phone is in pairing mode.
Choose "Settings" on the iPhone homescreen.
Select "General," then "Bluetooth."
Select to turn Bluetooth on.
Wait for the phone to search for in-range devices.
Select theMotorola HS850 from the list of devices.
Enter the headset passkey to complete the pairing. By default this is "0000."
Have a nice day..
Feb 23, 2011 | Motorola Mobility HS850 Consumer Headset
Can i pair my new iphone with a used plantronics 220
Yes, sure. Begin with the headset turned off. Then, press and hold the multifunction button until the blue and led lights flash alternately. The headset is in pairing mode. Now, make your iPhone's bluetooth application ('Home screen > Settings > General > Bluetooth') search for new devices. After a while, the heaset will appean on the phone screen. Select it and command the application to proceed. If a pairing code (or PIN, or passkey) is resquested, enter '0000' (four zeros).
Hope it works for you.
Cheers! Carlos
May 14, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Pairing my Z9i v1.1 headset with my new iPhone
enjoy
Jan 06, 2010 | Blueant Z9i Bluetooth Headset
Iphone and headsets
Yes, you can pair your iPhone with any bluetooth headset. I have used many different Plantronics headsets and all have worked perfectly.
On the iPhone, go to Settings (the gears icon), click GENERAL, then Bluetooth and make sure it's switched to "On". Then, follow the pairing instructions that come with the headset.
Oct 07, 2009 | Motorola Mobility Bluetooth...
I can't get my new iphone to pair with my BlueAnt.
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Aug 12, 2009 | Blueant Z9 Wireless Headset
My iphone is not discovering my blue tooth head set, why?
Make sure the bluetooth headset and the iPhone are both in pairing mode. Set the headset in pairing mode first and once set then go and turn on the iPhone bluetooth. It may take about 30 seconds to a minute for it to find the headset. Once the iPhone has found the headset make sure you select it on the phone and it will pair from there - Hope this Helps!!
Jun 08, 2009 | Apple iPhone Smartphone
Pairing headset
you need to have the manual for hour jawbone headset and follow those instructions.  You have to put the headset in "pairing mode" and then once you do that (follow headset instructions) it's simple to just go to settings, bluetooth and tell iphone to search for the headset.
Instead of headset issues, we're having car speaker phone issues.  I have the iphone paired with a motorola bluetooth car speaker, and it works when you are making calls.  However when a call comes in, the speaker doesn't pick up, the phone just rings as normal.  That's a problem as you need to be hands free in our state, and if a cop happens to see you, you're in for it
Nov 21, 2007 | Apple iPhone Smartphone
Samsung WEP170 Wireless Headset Logo
295 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
