I have a Sony KV-32HS420 projection TV. When you turn it on you hear a click and the sound comes on for an instant but the picture remains dark. The standby light then blinks 7 times and then repeats 7 blinks repeatedly.
  • 19,396 Answers
Hi.
The TV clicks and shut down because an internal fault is detected. This cause the TV shutting down and going in protect mode.
To start ensure that you go through the basic troubleshooting illustrated here: Why my TV does not start up?
Basic troubleshooting consists in disconnecting the power cord for fifteen or twenty minutes.That will hardly fix the problem, but must be done.
If that does not work, 7 blinks means that there is an horizontal deflection problem.
This is usually caused by faulty convergence ICs. Both the convergence ICs located on the D board must be replaced. The Pico fuses located near to the ICs must also be replaced.
Job is done de soldering old components and soldering new ones on board. Better using soldering compound to do the job.
The ICs to replace are marked IC8002 and IC650. They are both MCZ3001D (power amps). The ICs must be de-soldered using a proper iron. The cost of each IC is about $15, the labor is about $100/$120.
If you want a quote on repair or if you want to contact a qualified technician ring the number listed on the owners manual or see Sony eSupport
Posted on May 26, 2010
Stand by timer sony triniton color tv Model kv-32hs420
How many times the standby button blinks before going OFF at one time switch ON?
Apr 17, 2012 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony FD Trinitron WEGA KV-32HS420 32" TV.....Turns
Sounds like a diode may have burnt up or if your really lucky it might just be the fuse.!!! You might want to get a secound opinion .But if you know what to look for , which is any component on the motherboard that appears as if had caught fire sader it out amd replace with exact same component which can be ubtained at radio shack.GOOD LUCK TOO YOU!!!!!!!!!
Dec 23, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony tv model kv 32hs420 turn on hear relay kick then shutdown no picture no sound and no red light I replaced 2 IC MCZ3001d
You may have a problem with the capacitor. Normally the ones on the power supply circuit are the first ones to go out. Have it inspected for leaks or swelling. Also check out the unit for burnt resistors.
Dec 10, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony KV-32HS420 Trinitron Wega TV will turn on but then shuts off again after 5 seconds, never showing a picture. The "Stand By/Timer" red light on front blinks 7 times, pauses, and then repeats. I've...
You have what is commonly known as a shutdown problem. It's an overload in one of the internal circuits. It needs to be looked at by a professional tv reapir person.
Nov 03, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
My Sony kv-32hs240 turns on and after one hour
Sounds like you've got a short in your house electrical lines. Try using a surge protector (AKA power strip) between the power cord and wall outlet. If you've already got a surge protector, try replacing it.
Oct 29, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Tube does not turn on
If TV model is Sony KV-32HS420 then mostly it requires to replace 2 ICs on DZ board, let me know if you can replace ICs on circuit board and know about TV repair to provide you more technical info.
Thanks.
Sep 16, 2009 | Sony FD Trinitron WEGA KV-32HS420 32" TV
Sony KV-32HS420 will not come on has blinking standby light
Get out your original remote and hold the "Setup" button at the same time as holding the On/Off button on the TV set. It just worked for me!! Thank goodness. I was just about to bring it for repair but there's a snowstorm. Here's the link I got this from: http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=http--esupportsonycom-perl-tutorial-displaypltutid297templateid1regionid1KSMFlag7370&sliceId=&docTypeID=DT_TUTORIALS_1_1&dialogID=53101564&stateId=0%200%2053105132
Nov 16, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony KV-27V36/ No Picture
could be just a fuse or then again if its a plasma the light could be out either way to avoid getting shocked see a tech
Jun 30, 2008 | Sony KV-27V36 27" TV
Televison & Video Logo
214 people viewed this question
Top Televison & Video Experts
