Question about NorStar T7316 Corded Phone
Show telephone's own ext. number
One of our boardroom telephones is programmed to display RED BRDRM when calling from that ext number. Recently we had the technician in there and I feel he may have changed the port where the telephone is connected as when we call the number we used to dial for that Board room we get NOT IN SERVICE message however calling out from Red Board Room is fine.
Is there a feature on the phone that I can type in a code and it will display for me the extension number of that phone?
Thanks for your time
  • ksc3323 May 27, 2010
    Thanks will try that.
    Tried your second suggestion already though. The phone is programmed to display REDBRDRM so the number does not appear.
    Will def use the Feature * 0
    Thanks
    President:
  • NorStar Master
  • 860 Answers
To find out what the extension is in the board room,on the board room phone press feature *0 then press one of the intercom keys. You could also call another extension from the board room phone and see what extension number is on the display of the phone being called.
Posted on May 26, 2010
How do I program the T7208 telephone to display incoming telephone numbers?
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Sep 30, 2014 | Nortel Networks T7208 Telephone
How do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
When calls come into the office ext. 10 rings. It's the receptionist's desk. However ext. 29 rings too. How can I stop ext. 29 from ringing on all incoming calls?
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
The display should say system programming
Press the right hand intercom once. The display should say Central telephone Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Oct 26, 2010 | AT&T Lucent MLS-12D Phone
How do I turn off the ringer for the fax line?
I'm guessing that the fax line also appears on the telephone sets and rings on them.
Aug 24, 2010 | Lucent PARTNER18 Corded Phone
How do i program my nt8b20af-03 with an extension number?
If you plug the telephone into an activated (connected to the Norstar System) telephone jack, the lights should begin to blink while the phone boots-up. The system automatically assigns an extension number. To see what the ext. # assigned to the phone is, press "Feature * 0" (Button Inquiry) and press an intercom button. This will display the ext, # and Set Name of the phone.
Good Luck!
Aug 18, 2010 | NorStar Meridian M7310 Phone
I can't make a call or receive calls, I tried unplugging it several times and all the lights starts blinking!! When I try to dial a button, it gives me a busy signal.
You are probably trying to dial out on an intercom button. This will give you a busy every time. You may have to dial 9 to get out.
To test your phone, 1st find out what your intercom number is (press feature*0 and then press the intercom button) Your display will show you the intercom number of your telephone. Then try to make an in house intercom call to another working telephone. If that works have them call you back.
The next step is to find out if you have any lines programmed to your phone. (press "feature*0) and then each button on your phone. The display will show you what is programmed on that button. If you have any that say "001 Line001" or such those are the outside lines to dial out on. Hope this helps.
Bill C. www.dyna-tech.us We provide remote programming and tech support for Norstar CICS MICS and Call pilot 100/150.
Mar 11, 2010 | NorStar M7310 Corded Phone
Assign a new person to an extension
Changing the programming2.gif on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
press the left hand intercom button
the display should say central telephone prog extension:
enter in the extension number of the persons phone you wish to rename
the display should say program extension xx
the display should say the extension number followed by the existing programmed name
enter in name of new person by pressing the number where the letter is then its order on the button so under the 2 button 1 would be A, 2 would be B, and 3 would be C ex. BILL = 22 - 43 - 53 - 53 use the mic/hfai button to erase entry.
either press the right hand intercom to go to the next extension or press feature 00 to exit
Oct 19, 2009 | Avaya Corded Phone avaparp18d
I need to re-program the day on avaya 18d telephone.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
enter in "#101"
the display should say system date and the current programmed date.
enter the new datein MMDDYY format
press feature "00" to logout
Older partner systems also had an additional place to program the system day
enter in "#102"
the display should say system day.
the display should have the current programmed day of the week
press the digit for the day of the week (1=sunday 2=monday etc.)
Sep 29, 2009 | Avaya Partner 18 Eurostyle 18D telephone
How to find unknown incaming calling location
I can think of 2 possible causes:
1) The call originated from an International location and you are seeing a partial originating telephone number.
2) The originating caller has a type of telephone service that allows their telephone system to generate the digits that appear on Caller ID displays. Their telephone is creating that strange looking telephone number.
My guess is that the first cause is the correct one.
You can try googling the numbers on the display to see if anyone else has had this happen to them. Your telephone service provider could run a trace on the call, but that would require going through a legal process that, if this is a one time event, would really not be worth the hassle.
Dec 24, 2008 | Uniden Cordless Phone
Programing my nortel t7316e charcoal to access whole phone lines
If you are fmailiar with the programming of the system, you must set the lines (3-8) to appear and ring on the extensions.
Assuming you have a later release MICS or CICS:
Press Feature ** 266344, then the installer password.
Press Show at Terminals and Sets, enter ext #.
Press Show until you are asked for the line number, then scan through the line appearances, and change to "Appear Only" on the lines you don't want to ring at that set.
Repeat for each extension you want to change.
DO NOT DO THIS UNLESS YOU ARE FAMILIAR WITH PROGRAMMING.....
Nov 11, 2008 | NorStar T7316E Corded Phone
NorStar T7316 Corded Phone Logo
139 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
