Question about D-Link Xtreme N DIR-655 Wireless Router
WEAK signal :-( How do I extend the distance or wireless reach.
The wireless 655 is shared by 2 computers about 60 feet apart in 2 bedrooms but between 3 brick walls. It is mounded about 20 ft. from one computer to be able to also connect the 20 ft. PC cable for video better quality watching movies through SLINGBOX. One computer get all 5 bars and the other that's always wirerless only gets 2 bars. HELP!
Thanks ,
PANAMAC
    Novelist:
  • 210 Answers
Either look into getting bigger (higher gain) antennas for your router, or get bigger/stronger antennas for your PC's.
Other than repositioning the existing antennas or putting the router higher up in the air, there isn't much you can do.
Posted on May 26, 2010
What kind of wireless access point or extender should I use to project wifi in far bedrooms of a long, train-car like house?
Hi James, the wireless extender is the best way but you should go for the plug in type.....this plugs into the mains and gives you wifi and 1 wired connection, so you can plug into the room you want wifi to reach, I have linked a Netgear option but there are others! EX2700
Jan 18, 2015 | NetGear Computers & Internet
Tip
Using a network extender at home
Network extenders and repeaters work to extended the range of your wireless network. You don't have to live in a big house to need an extender, where I live houses are made of concrete which makes the wireless signals a little weak when you're not in the same room as the router. I had played with the idea of getting another router to put upstairs since the signal wasn't reaching from the office on the first floor to the bedrooms on the second floor. But setting up the router and the network was going to be time consuming and I was just trying to make the signal reach a little farther. That's when I discovered repeaters, I set up one repeater at the top of the stairs in my house where the signal began to weaken and ta da! The network now reaches the whole house at full strength and I didn't have to set up a new network.
on Sep 17, 2013 | Computers & Internet
What kind of wireless access point or extender should I use to project wifi in far bedrooms of a long, narrow house?
Yes. You are right on track with hard wiring the extender unit. You can also daisy chain another router to that at a distance that is closer to the furthest room. This will give you plenty of signal through out your house.
How do I extend wireless coverage?
Extend the range of WiFi signals with Hardware If your router is placed on the ground floor of your home, the Wi-Fi signals will be very weak or may not even reach the basement computer or the printer upstairs. The situation will be no different if you work in a fairly large premises or if there are too many walls in the area.
In that case, here are some hardware device that you can consider to extend the reach of your Wi-Fi network:
wifi_repeater_thumb.jpgOption #1. You can attach a WiFi Repeater (also known as Wireless Range Expander) to your router and quickly expand the coverage of your wireless network without using any cables.
The Repeater should be placed within the range of your existing router and it will reflect the signals to other areas where the wireless reception was earlier poor (or totally absent). The Repeater can connect wirelessly to both routers and access points (see #3 below).
Option #2. (This is my current setup) You can get another wireless router and connect it to your existing router using an Ethernet cable. The advantage is that this setup comes pretty cheap and the Internet speed stays almost the same even for computers that are accessing the web via the new router.
You can get a 100 feet long Ethernet Cable (also known as Cat5 or LAN or RJ45 cable) for less than $10 and wireless routers start at $20. Here's a detailed guide on how you can connect two routers together.
Option #3. You also have the option to use an Access Point instead of a router to extend the WiFi range but that's often not required because Wireless Access Points can be more expensive than equivalent routers.
The other advantage with a router is that is has extra LAN ports so, in future, you can connect more wired computers for sharing files or you Internet connection.
Option #4. If you have an old desktop or laptop computer, you should consider adding an external (USB based) wireless adapter or upgrade the internal network card to improve the wireless reception (and thus Internet speed).
Jan 04, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Can not use laptop 35' away , works ok at 15' .Can distance be increased?
yes but you will have to buy a signal booster (also know as a range extender) you can find them at places like walmart and other stores that sell computer wireless modems.
Dec 14, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I have about 300 meters distance and I would like to connect my internet connection to the end. I'm using smart bro connection, is it possible using router to spread signal of internet on wireless with...
Wireless-g router can only extend it's wireless signal up to 50 to 75 feet. You can use a wireless signal extender to be able to extend the signal further. And yes, you may have password on the wireless network.
Jun 07, 2010 | Linksys Wireless-G WRT54G Router
Weak signal
Go to your basic setup and change IP. Your default is 192.168.1.1 you can change it to a higher number
(ie:192.168.1.4) Also make sure and set up security.
If you leave it open others can use your connection and slow you down.
Oct 21, 2009 | Linksys Wireless-G WRT54G Router
No Wireless Connectivity
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from other wireless routers and access points in your area.
Oct 09, 2009 | D-Link DIR-655 Wireless Router
Linear equations
This question is strangely worded and does not pertain to floppy drives. However, taking all information here as given and sufficient enough to form the equations, you arrive at the following:
X=Y+60
60(3.25) = 195 One tenant must pay $195 more for his extra 60square ft.
(975-195)/2=390 The remaining rent (assuming the given info is all that is needed to solve)
390/3.25=120 is divided between the two and represents the rent of the smaller bedroom.
y=120 sq ft The rent of the smaller room holder is divided by $3.25 to reach the sq ft.
so,
x=180 sq ft
Sep 17, 2008 | Computers & Internet
We just bought the d-lin wbr-2310....
there is no any other special settings if u keep the laptop very far it will not receive the signals >try this login to ur router and change the wireless channels use 1>or 11>it may help to improve the signal strength>and check with antena on the router weather its straight>rate me solved if its help full
Nov 04, 2007 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link Xtreme N  DIR-655 Wireless Router Logo
325 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
