FixYa.com
Tags:
Microwave Ovens
Generic problem for all Microwave Ovens
KITCHENAID KEHC309JSS05 NO POWER
posted by luistorres on Apr 07, 2008
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 08, 2008
Not Rated (0)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2719 votes
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again. If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE JVM1790 1000 Watts Convection / Microwave Oven GE XL1800 1100 Watts Microwave Oven GE Advantium SCA1000H 900 Watts Convection / Microwave Oven GE Advantium SCA1001SS 900 Watts Convection / Microwave Oven GE Advantium SCA2000B 950 Watts Microwave Oven GE CVM2072SMSS Stainless Steel 1100 Watts Microwave Oven GE JE1360 Microwave Oven
Can you Help with these Microwave Ovens problems?
Microwave Ovens
microwave will run but won't...
my JVM1631WB002 model GE... Answer This...
GE JVM1850 1000 Watts Microwave Oven
Replaced key panel for F3...
I read on a previous post that... Answer This...
GE JE2160 1150 Watts Microwave Oven
I have display, but no lights,...
I found the envelope inside... Answer This...
Microwave Ovens
GE JES1456WF001 NO COOK
oven would sometime come on by... Answer This...
Whirlpool MH1150XM 1000 Watts Convection /...
Replacement of Door handle
How do you replace the door... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
