Question about GE Profile Harmony DPGT750EC Electric Dryer
GE Harmony Profile Dryer DPGT750EC1PL not heating & blower not working
I have a technical question for your team. I've installed the thermistors in my GE Harmony Profile Dryer, Model# DPGT750EC1PL and I am still having intermittent problems. The dryer ran fine for 5 loads and then it stopped drying intermittently. Here are the systems:
  • Dryer turns on and spins properly
  • Control panel seems to work properly
  • Dryer does not heat up
  • Blower does not blow air
  • Dryer completes entire cycle but clothes are still wet
  • This problem occurs about every other load
If you can help with some ideas to check, that would be great.
  • 3 more comments
  • Woodjunkie Apr 07, 2008
    Thank you for the general feedback. I would think these answers apply to most dryers. Here is some feedback to help you get a little more specific.
    * The dryer does not heat at all at the start and during cyclnig so it is unlikely it is hitting the High Limit.
    * I've completely dissassembled the dryer and the vent and all is clean and vacuumed.
    * The settings for drying are the same as we have always used and it is unlikely this is the root cause of the problem.
    * Taking a voltage of the blower motor while in operation would be very difficult because I have to dissassemble the entire unit to get to the motor.
    * The heating element looks visually fine and when the dryer does work, the clothes are completely dry and the dryer seems to get up to heat appropriately.
    * If this dryer does have a thermal fuse, then it seems to still be operating because the dryer drys properly every other load.
    * Both thermistors have been replaced so it is unlikely that this is the problem.
    With this additional insight, can you recommend anythnig else I may try? Also, would you have an technical manual for this dryer.
    Thank you again for your assistance.
    Regards,
    Robert
    The belt seems to be turning the drum well and when I re-installed the drum after disassembly, the belt seems to fit tight. Also, there is a prox switch on the idler pull arm that would probably trip if the belt were too loose.
    The link provided no help and was not specific to my problem.
    The service manual may help but I was hoping to get some specific expert advice on what to check next.
    Robert
  • Woodjunkie Apr 08, 2008
    If anyone can provide additional help for me GE Harmony Dryer, it would be appreciated.
    The symptoms are:
    Thank you,
    Robert
  • Woodjunkie Apr 09, 2008
    Thank you for the tips. I have ordered new thermostats and a sensor and will install them as soon as they arrive. I'll also check the items as you suggested.
    I've already installed the 2 new thermistors. As far as the timer element, it is an electronic panel and not a mechanical timer so I don't think that the timer contacts would be burnt.
    It may be a couple days but I'll let you know how it goes.
    Thank you,
    Robert
  • 3,037 Answers
See if the heating elements are loose or if the connection is dirty first and let me know what you find. It sounds like they are the root of your problem.
I would also following the heating elements back to the board and follow their pattern and see if somewhere that the metal is loose and just touching every once in a while.
Thank you
Posted on Apr 08, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri Apr 08, 2008
    A couple common trouble area's for intermittent heat on a GE built dryer
    besides the heating elements themselves which are behind the drum, are if the timer
    contacts are blackened and burnt or if the motor heat switch is not closing when
    the motor starts up
    Please update me on the situation after checking these areas and I will see if I can get you a manual
  • Benjamin Patri
    Here is the manual, you may have to sign up on the website for free to view it but it won't cost you anything
    http://www.managemyhome.com/mmh/lis_pdf/...
    Just click on the above link please
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    Were you able to fix this problem?
    Please let me know
    Genius:
  • 3,422 Answers
HI,
If your blower stops working, the element will overheat and trip the high limit, thats is why you have no heat.
The trick is to find out why the blower isnt working. It should be found under the dryer. Its possible that there may be a loose wire. It could be getting ready to go out. I would run the blower motor, observe it when it stops, then take a voltage reading. If voltage is presnet at the blower motor, and the motor isnt working, then the motor needs to be replaced. If voltage is not present, then we must determine why.
If your dryer is not getting any heat, you need to make sure there is nothing blocking the front of the dryer. Air flow is key to efficient drying. Make sure the dryer settings are appropriate for the clothes you want to dry. The timer selection, fabric selection, and the temperature selection all play important roles in proper dryer operation.
Check the heating element, burner operation, ignitor, thermal fuse, and the wiring (power cord).
Visually inspect your heating element for any broken or burned areas. The heating element is a coil made from a nickel-chrome alloy, called nichrome. Check the coil for continuity with a Volt Ohm Meter. If there's no continuity, it means that the element is bad and you need to replace it. An electric dryer should have it's own separate power line.
When the burner is operating properly, the flame should be clean and blue.
If the ignitor is cycling without the burner lighting, you probably have defective electrical coils in the gas valve. These coils look like black cylinders with wires coming out the top of them, and are located near the burner valve assembly. When they get power, they open up and allow the gas to get through to the burner. If this is a new installation, make sure the gas valve is turned on.
If the ignitor doesn't glow, look for a white or yellowish discoloration, or for a break in the ignitor. If this is something visible, just replace the ignitor. If there are no obvious signs of a break or burnt area, test it for continuity. If the ignitor doesn't have this type of problem, you'll need to determine if the problem is in the control area, or somewhere else within the burner system. Test for 110v getting to your burner assembly.
Here's a test you can perform: Unplug your dryer and then open up the burner inspection panel. Unplugging your burner assembly unit, you want to connect your jumpers for the Volt Ohm Meter to the dryer side of the assembly, not the burner side. Keeping your Ohm meter wires away from the drum area, set the timer to on, set the controls to high heat, and then plug the dryer back in. If there is 110v in this area, you can assume the thermostats in this area are good. If not, a timer, motor centrifugal switch, or other thermostat may be your culprit.
To protect from over-heating, many dryers use what's commonly called a thermal fuse. If the thermal fuse gets too hot, it will blow, and completely shut down your dryer until it is replaced. This fuse is often mounted within the exhaust duct in the back panel. It's about an inch long, and is usually found within a white plastic housing. When fuses blow, it means they have no continuity and no power will flow through it. A bad thermal fuse needs to be replaced. When replacing this fuse, check the dryer vents to make sure there is no lint buildup which can cause the heat to stay trapped and blow the fuse again.
You should visually inspect the wiring connections to the dryer from the house regularly. If you're opening the dryer case, give the wiring inside a good visual check as well.
Lastly, never use an extension cord to operate this appliance. An electric dryer draws a lot of power, and the shorter the wiring to it, the better. The power cord connects to a terminal block in the back of an electric dryer. Sometimes this terminal can get burned out or ground to the dryer. Make sure the power is turned off, and look for scorching, burned, or broken connections. For electric dryers, one broken connection might allow the dryer drum and timer to operate, but there would be no heat.
If your clothes are wet then:
This is usually caused by poor airflow. Turn your dryer on and go outside to the vent. If there is not a strong airflow, check your dryer duct vent, lint trap, blower, and also look for clogs and kinks in the vent hose or ducting. Ductwork inside the dryer may become clogged. Use a long flexible lint brush or vacuum attachment to clean these ducts. Make sure the air path is clear from the burner assembly or heating element all the way to the exhaust vent.
Some electric dryer heating elements have two circuits in them. Sometimes one can burn out. If one part is not working properly, this can lead to a dramatically longer drying time. If this happens, you'll want to just replace the whole heating element since the individual circuits are not available separately.
Another reason for damp clothes would be one of the cycling thermostats. These control the temperature in your dryer and when they fail, they prevent the dryer from heating well or stop it from operating altogether. To locate and replace a thermostat, follow the duct work that moves the air through the dryer. A thermostat has 2 to 5 wires attached to it, and the body is black or brown. On the end opposite the wires is a metal plate that is used to attach the thermostat to the duct work.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 07, 2008
  • 2 more comments
  • Priya darshan Apr 07, 2008
    Please give me few monute i'll let you know if there is any service manual available
    The first thing is please check THIS LINK out for more info
    Click HERE to buy the service manual(mini manual).It is not available for free.
    Goodluck once again,
    And please don't forget to rate the solution.
    I believe that there is no problem with the belt.
  • GE Master
  • 19,396 Answers
Check that the dryer belt is not lose or out of place.
Ge profile dryer does not heat at times
Sounds like one of two things.
1) you have a bad connection, specifically, a loose connection that is making contact once in a while.
2) one of the "overheat thermostat switches" is failing.
If you wish to fix it yourself, you will need to dismantle the machine and have a testing instrument to look for the problems.
Be advised, however, if you take it all apart and it happens to be on a "I will be working now, thank you very much" cycle, you may not find anything!
It really needs to be "not working" for the flaw to show up.
Be blessed.
Feb 22, 2013 | GE Profile Harmony DPGT750EC Electric...
Runs but no heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
May 29, 2010 | GE Profile Harmony DPGT750EC Electric...
GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Dec 22, 2009 | GE Profile Harmony DPGT750EC Electric...
DescrI have a GE profile harmony electric dryer model #dpgt750ec1pl. About 5 minutes into a drying cycle the blower shuts down. There is still heat but no air coming out of the dryer duct. Any suggestions?...
you should not have heat when motor stops there is a switch in the motor to shut the element off....yours is not working(you could burn your house)replace the motor.
PLEASE DO NOT TRY IT AGAIN...can't be lucky all the time
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
OUR G.E. PROFILE DRYER MOD.# DPGT750EC1PL STARTS AND RUNS LIKE NORMAL, BUT THE BLOWER DOES'NT BLOW. WHAT DO WE NEED TO LOOK FOR SO WE CAN GET THIS DRYER RUNNING? THANKS.
The fan motor must be tested by energizing it and reading volts from timer control. If the fan is faulty it must be replaced, if there is no volts from timer control, then either wiring harness or timer control assembly must be replaced.
Jul 04, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony won't heat up and blower does not work
Found Manual here:http://www.affordableappliance.com/Download%20Folder/GE_Harmony_Dryer.pdf
GOOD LUCK!
Mar 11, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge harmony dryer not heating up dpgt750ec1pl
If you hear the blower ramp up when you start the dryer and if slowly ramps down or quits all together then you need to replace the blower. If the dryer heats at all then look at the blower.
Jun 20, 2008 | GE Profile Harmony DPGT750EC Electric...
First use the dryers service mode and see what trouble code you are receiving.
It's called "Field Service Mode"
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
There's a 95% chance that it is your blower and your dryer should confirm that.
I just recently replaced the blower in my GE Profile Harmony as well. While I had my dryer apart, I also cleaned the heck out of it. Excellent opportunity to take your vaccum cleaner and get all of those dust bunnies out!
I purchased the blower from www.applicancepartpros.com for about $146 S&H included.
Part No. AP3791484 Item: Motor asm-blower Price $133.05 Plus Shipping.
Mar 12, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer Logo
604 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
