Question about E-Machines W3107 (RBW3107) PC Desktop
Power problem; Nonstop fan
I need step by step instructions on how to get the "E_Machine W3107 PC Desktop" working again when the fan runs nonstop and the monitor doesn't show a picture.
    Novelist:
  • 145 Answers
Here is what you do, it is for unfreezing the bios. Open your computer and look for the bios clock battery it will be silver and the exact roundness as a nickle. you will be able to remove it rather easily the number should be CR2025 on the battery. you can buy these from most stores actually, radio shack, walgreen's. walmart, ect. before you leave for the store unplug your computer and hold the power button for 15 seconds, " this clears the power " leave it unplugged until you have a new battery, Once you have a new battery install it with the + facing in the open and the unlabeled side facing down into the slot. plug your computer back in and boot, it may cycle through the Bios restart once, from there it will restart again and you should be good to go.
Posted on May 26, 2010
The drain pan is dry. There is ice buildup on the top half of the defroster. The compressor runs nonstop. The temp doesn't get any cooler than 45. The condenser is clean enough to see through and the door...
Is the evaporator fan motor running? If it is only running at half speed or not at all, that could explain the ice buildup. If the coils are icing up because of no air flow over them, then the defrost heater stays on, trying to get rid of the ice.
Sep 14, 2013 | True T-49 Side by Side Refrigerator...
Radiator fan running nonstop
Hi Bro, Have you check one single wire to switch temperature, if this unplugged the fan will run nonstop, even without your engine start and your key is in "ON" position, it's exactly what happen to my 1994 corolla
Mar 20, 2013 | 1990 Toyota Corolla
My pc workstation gives no beep codes when i start it and the fan blow very high nonstop no display.
this is a desktop pc, it sounds like you have a start-up problem, i would pull the ram first and try to boot if it boots okay, put one stick back in at a time to find out which one is bad, if it doesn't boot you may have a bad cpu or motherboard.
Aug 02, 2012 | Fujitsu Siemens Computers & Internet
Both sides are warmer than should be. motor running nonstop
You refrigerator needs regassing that is why things are not cooling. Your sides of fridge are hot because the motor keeps running to keep what gas is there flowing though the lines trying to cool fridge
May 25, 2010 | Maytag MZD2766GES Side by Side...
Emachine w3507 blue light only comes on fan runs nonstop, no signal or monitor, pressing the f8 did nothing
If you get nothing but a blue light and no video at all it sounds like you have a bad power supply. They are easy enough to check and replace but not for a first timer. If you know someone who knows more; get a volt meter and put it on the DC scale. Unplug a power plug to a drive or find one that is not used. Measure the Yellow to black and then the red to black wires. You should get 12 & 5 volts respectively.
Apr 18, 2010 | eMachines W3507 PC Desktop
Freezer motor running nonstop
Behind the back panel you will find the freezer fan motor. unplug and take everything out. take the back panel off and find the fan. stick something in the blade like a bannana or whatever (no rags or paper towels though) just something to jam the blade (its plastic so dont break it) replug. remove whatever you put to jam the blade and if you hear the sound then you know for sure it is the fan. got to replace fan if you want the noise to stop
if it is not the fan let me know
hope this helped
Apr 01, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
No signal to monitor, fans run full speed
maybe your cpu is faulty or ... maybe power suply ??
Mar 31, 2009 | E-Machines W3107 (RBW3107) PC Desktop
W3107 no signal from computer to monitor
check the requirements of your game who you played maybe your VGA card cannot support the requirements of the game. and also check the resolution maybe it cannot support.
Jan 07, 2009 | E-Machines eMachines Desktop PC
Hanging problem
D845GBV no display in skrin.bib tone continuously for 03 times nonstop, after which nothing happens except for cpu fan running.
Sep 03, 2008 | Intel D845GVSR Motherboard
E-Machines W3107 (RBW3107) PC Desktop Logo
117 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
