Question about Boating
Have mercury 65 hp, pretty old. not circulating water fast enough to keep engine cool. only dribbles from tell tail. checked impeller and is v good, also romoved robber pipes to tell tail and all clear. please help:-)
    Top Expert:
  • 44,327 Answers
Rebuild the water pump . the metal housing go bad also thru many years of grudge going thru them. you might also have sand etc in the block requiring heaad removal and blow the passages out
Posted on May 27, 2010
Little heat coming out of heater on 1999 chev 1500
You have a vapour lock. The coolant isn't flowing. The remaining water is not cooling your engine evenly so you could crack your engine block. The water that isn't circulating turns to steam. The water pump could need replacing if the impeller failed. You may need a new thermostat. Get someone knowledgeable enough to fill your radiator properly and then keep the overflow reservoir filled to half. Check that bottle at least every week.
Nov 29, 2013 | 1999 BMW 323 Series
I have a Mercury 7.5 hp 2 stroke engine,At high rev there is good water circulation, but at low rev when fishing there is no water circulation. Is this normal? Bob
No, you should always have water shooting out of the tell-tail port at all engine speeds. The impeller in the water pump assembly is worn and will need to be replaced. It seems like it compensates with higher revs,but can not provide the water volume at low revs.
Jun 09, 2010 | Boating
Replaced waterpump, still overheating lights comes on
Check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Mar 18, 2009 | 2005 Chevrolet Impala
My 1995 toyota avalon is overheating. When this happens, antifreeze fills up my reservoir container, even when I didn't put that much antifreeze in it.
Mar 14, 2009 | 1995 Toyota Avalon
My sklyark is overheating. I changed the thermostat and the starter! WTF is wrong???
Check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Mar 09, 2009 | 1995 Buick Skylark
Overheating
The thermostat is behind the upper radiator hose...remove the upper radiator hose and loosen and then remove the two bolts on the outlet (where the upper radiator hose ends) The thermostat is inside that outlet...Another thing to check is if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Feb 28, 2009 | 1997 Nissan Maxima
Overheating
Feb 25, 2009 | 1994 BMW 3 Series
1990 ford ranger is overheating
If the cooling system has no bleeder valves to vent air, you may have to temporarily loosen a heater hose to get all the air out of the system...Also check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem....Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty Water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Oct 20, 2008 | 1998 Oldsmobile Bravada
Overheating
Check to see if there is water in the oil...If there is water in the oil then it could have a head gasket problem..Did you ever replace the thermostat? If it is stuck then it would also cause overheating...Excessive exhaust backpressure because of a clogged catalytic converter could also cause overheating..Also check belt tension and condition. A loose belt that slips may prevent the water pump from circulating coolant fast enough and/or the fan from turning fast for proper cooling...Another thing it could be is a faulty water pump -- Any wobble in the pump shaft or seepage would call for replacement. In some instances, a pump can cause an engine to overheat if the impeller vanes are badly eroded due to corrosion or if the impeller has come loose from the shaft. The wrong pump may also cause an engine to overheat. Some engines with serpentine drive belts require a special water pump that turns in the opposite direction of those used on the same engine with ordinary V-belts... Also check the Fan -- With mechanical fans, most overheating problems are caused by a faulty fan clutch, though a missing fan shroud can reduce the fan's cooling effectiveness by as much as 50% (depending on the fan's distance from the radiator) which may be enough to cause the engine to overheat in hot weather or when working hard.
Aug 06, 2008 | 1998 Plymouth Breeze
Boating Logo
73 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
