Question about LG LRE30755 Electric Kitchen Range
Burner on range will not turn off
I have a ceramic glass cook-top electric range (Sharp KB-3300J) with built-in microwave drawer. I'm having an issue with the right front burner not turning off when the knob is in the off position (The right front burner also has small and large cook areas controlled by the same knob). The first time this happened I noticed the hot surface indicator remained on longer than normal and it felt like the burner was putting off heat (although no red glow was seen). I unplugged the range, waited about 15 seconds and plugged back in. I then turned on the burner - large cook area. I saw a red light flash (kind of like when a light bulb burns out) in the center of the cook top (not where a burner is), then the right front burner turned on (glowing red). When I turn the knob to off the on/off indicator light went off but the burner remained on and glowing. I can unplug the range and repeat this process. The other burners appear to work normally as does using only the small cook area on the right front burner.
My questions are:
1.) what's causing this problem and how to fix?
2.) if I don't use the right front burner will it be safe to leave the range plugged in and use the remaining burners, oven, and microwave?
Thanks
Jon
  • 4 more comments
  • gapscap Jul 28, 2008
    I have a Frigidaire PLEF398AC Electric Kitchen Range that the left back burner will not go off when I turn the dial to the off position. What causes this and can it be fixed. I have only had this range a year!
    We unpluged it and left it unpluged for about 30 minutes. An error code came one when we plugged it back in.
  • johnme7 Sep 15, 2008
    Same thing with my front left dual burner... the inner (smaller burner wouldn't trun off and when I got it off the burner actrually turned itself back on at one point so I have the breaker off now
  • bakingmom Dec 23, 2008
    I have an LG LRE30755ST stove, left front single size burner will not turn off. I must unplug the stove to get it off. It heats back up when plugged in. Sometimes the larger part on another burner comes on when not turned on.
  • Anonymous Dec 31, 2008
    I have the same problem. My front right burner does not turn off. Instead, it powers on and off all on its own. Solutions would be appreciated!
  • jbull971 Mar 28, 2009
    I have a fridgedaire ceramic top range.When I look through the front vent I can see that the stove element is on.None of the elements are on and the heat warning light is not on. The top f the stove is hot but it can be touched.Why does it come on and how do I get it to go off?
  • Dennis Stone
    Dennis Stone Aug 05, 2018
    This will happen sometimes to my 15 year old Amana glass top range. I put a tray, large pan on top of the glass stop and add a layer of ice cubes. Watch that the melting ice don't overflow the pan or tray. The light went off. I did this a week ago and the light has not got stuck again.
    New Friend:
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Posted on Nov 03, 2010
I am having a similar problem with m Fridgedaire. The left front burner does not turn off. prior to this problem, it took a looooog time for it to heat up... I have been turning the breaker off when not in use as it is difficult to access the plug...HELP?
Posted on Jun 17, 2008
I am also having turn off problem on smaller burner of dual burner glass stove as of 8/2/08. It remains on high even when know is in off position.
Posted on Aug 03, 2008
SOURCE:
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Home™ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
Can your microwave work without mica cover?
It can be, but it's not recommended. Food can splatter and get into the waveguide and cause problems. Also if you reach in there with your finger right after the microwave stops, you can get a severe shock (until the capacitor discharges, usually in about a minute). Also the edge is sharp.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Nov 07, 2014 | Sharp KB-4425LW Insight Pro Electric...
Is it okay to use glass whistler tea kettle on ceramic stove top range
I've seen mixed results across the internet on this one. From personal experience, for some reason, my glass teapot left some sort of stain on my ceramic stovetop. It also took longer to heat. I then went out and bought a simple metal one and have been pretty satisfied. If cosmetics are a concern, it's not too difficult a step to pour the water into your teapot after the fact, right?
Jul 23, 2014 | Frigidaire Ffed3025ls 30 Smooth Top...
Ceramic, glass top stove hot burner lamp stays on continuously even when the burner is off and is working normally.
Take your complete model number to searspartsdirect.com. You can find parts lists and diagrams there
Nov 19, 2017 | Frigidaire FEF366EC 30" Freestanding...
I have a GE glass cook-top electric range. burner stays on.
You need to replace the switch which controls the burner.
Apr 07, 2009 | Kitchen Ranges
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Soup boiked over on stove top
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Dec 17, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
I bought a Frigidare 30" Freestanding electric range model # FEFL79HB in July. I really like the flat glass top but have had problems trying to clean spills off of the top. Residue from cooked food...
Scotch brite has your solution they have a kit for cleaning ceramic cook tops ..
cook top cleaner kit
go to www.3m.com
there is also a coupon you can print out.
let me know if it works for you just like it did for me..
Sep 09, 2008 | Frigidaire Kitchen Ranges
LG LRE30755 Electric Kitchen Range Logo
2,108 people viewed this question
Top LG Kitchen Ranges Experts
Marvin
Marvin
Gene Pitts
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
