Question about Whirlpool Duet GHW9150P Front Load Washer
Code f12 - Whirlpool Duet GHW9150P Front Load Washer
  • 1,284 Answers
Hi, F12 means a communication error .Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
Potential Causes
• Check Wiring Harness connections to the MCU, the motor, and the Central Control Unit (CCU)
• Check the Drive system
• Check MCU
• Check CCU
• Check Motor
Replace failed part
Take care
Posted on May 26, 2010
F12 error flashing on the display
Keyword Ranking Analysis for ARISTON OVEN FAULT ...
www.webstatschecker.net/stats/keyword/ariston_oven_fault_code_f12
Keyword Ranking Analysis for ARISTON OVEN FAULT CODE F12 ... fixya.com.Ariston Technologies Ariston AWD120WH - "F12 error code" issues
Aug 18, 2015 | Ariston Technologies Ovens
F12 Bike Computer code for a fat tire bike
https://bugtingpreltab.files.wordpress.com/2015/10/bell-f12-bike-computer-manual.pdf
Mar 07, 2014 | Bell Sports Bell F12 Bike Computer
F12 error code
F12 SPECIFIC FOR LVB2000 INDESIT EVOLUTION / DIALOGIC.
F12: Lack of Display card-Main Card Communication
1. Check the effectiveness of contacts on CNC Connector Card
2. Overhaul 8-way connector on Display card
3. Check continuity of CNC-CN 8 way connector
4. Replace Main Card
5. Replace Display Card
Dado
Jan 23, 2014 | Ariston Technologies AWD121WH
F12 error code
Also here is a list of He2 error codes http://www.applianceblog.com/mainforums/sears-kenmore/10283-he2-error-codes.html
I think the error code you are actually getting maybe an F21 due to there is no listing for F12. use this kink to put the unit into diagnostics and run the diagnostic menu which will give you your exact error code as well. I await your reply
Thank you
Rick
Dec 02, 2011 | Kenmore HE2 Plus Front Load Washer
Hotpoint WF860 1600 spin machine keeps flashing F12. How can I solve it please???
Hi
The code F12 means the following:
F12 - No mixed fill. It is likely that the water is not turned on at the taps
Also Error code F12 is indicating a communications error between cards; Error code F12 is indicating a communications error between cards, this can be caused by one of several things. A problem with bad connections, if you can remove and then replace the plug on connectors, check for loose or chafed wires to motor, they can chafe due to tightness of wires, particularly down to the motor.
It is an electrical problem as opposed to a mechanical one.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | Hotpoint Ultima WF860 Front Load Washer
F12 code
Ive looked thru all my manuals and can not find a f12 error code anywhere even looked on-line all you can do is call Whirlpool in the morning and speaking with there customer service reps to find out what it is sorry for the troubles....
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint ultima washing machine has error code f-12
F12 - No mixed fill. It is likely that the water is not turned on at the taps.
here is a link to all hotpoint error codes:
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
If this helps please rate me
Sep 10, 2010 | Hotpoint Washing Machines
F12 code problem with indesit we16
F12 means no communicastion between boards.
Check all connections and wiring between the boards.
Good luck
Dec 14, 2009 | Washing Machines
Kenmore HE2 Plus Front Load Washer; Error Code F12
Is this a model 110.47512601 HE2 Plus? If it is, I do not see an F12 error code listed. I have a tech sheet for an HE2 Plus, but I only see an F21 error code.
There is a tech sheet inside your washer that explains all the error codes. You will have to remove the lower panel under the door to access it. Its usually mounted to the inside of the lower panel on along the interior walls of the cabinet. There will be instructions on how to enter diagnostics mode and a full list of error codes, followed by procedures to follow on how to correct. If you require further assistance in determining the source of the error, please let me know.
PS Don't tell Sears I told you where they keep their "secret" error code list. Don't you find that irritating? The repairman would have come to your home, opened the washer, and read the tech sheet right in front of you - then charged you for it. Good luck.
Jul 13, 2008 | Washing Machines
F12 Error
what is F12 error code on a siemans wxlp1400 and how do i cure the fault, cheers
Dec 29, 2007 | Siemens WXLP1460 Front Load
Whirlpool Duet GHW9150P Front Load Washer Logo
941 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
