Question about Cfm Daikin R410a Split System Air Conditioner
Daikin split system fine with cool air, not with hot air
My 10 year old daikin split system is fine when on cool but when i change to heat, it cuts out after 10 mins, no flashing lights, air flow just stops with power still on. turned main power of for 30 mins, didn't make any difference. how can it be fine on cool but not on heat??
  • 901 Answers
Looks like thermistor problem. take service help.
Posted on May 27, 2010
Can I run a daikin mini split heat pump 3MXS24JVJU with a generaton
It depends on the SIZE of the generator. If your generator is designed to supply 240-volt A/C and handle the FLA (Full Load Amps) rating of your Indoor and Outdoor units, then, YES, of course you can run it with a generator.
Aug 26, 2014 | Cfm Daikin R410a Split System Air...
Solution for u2 error
it sound like the outdoor pcb has failed, if your unit is less then 5 years old it will be under warranty. if your unit is a rxd50/60/71jvea it will be a fan motor and pcb
Mar 16, 2012 | Cfm Daikin R410a Split System Air...
I have a daikin split air conditioner after been on for 10mins it flashes L1 and cuts off,we have been waiting 4 weeks for Blueline to replace the boards as they said that was the problem since they...
Very simple. Please follow these steps.
1. Power off. 2. In three phase compressor terminal or in terminal block-interchange any two wires.
Now power on and start. Hope, you will be happy.
Feb 26, 2011 | Cfm Daikin R410a Split System Air...
Is a split a/c alc and a heating or heat pump?
a split system can be gas or can be a heatpump. a split system is when the condenser coil compressor and outdoor fan is outside. the other half is in the house close to your air filter .that well be your air handler. eletric heater. or gas burner .and indoor fan motor would be. i hope that helps you.
Apr 15, 2010 | Cfm Daikin R410a Split System Air...
Three month old R410A Daikin a/c not cooling?
Hi; dont worry unit is still under some kind of a warranty, either from installer or manufacturer. Please find out before You or a friend try to fix. This can void Your warranty...
Jan 20, 2010 | Cfm Daikin R410a Split System Air...
Theres a weird odour coming from my system, it doesnt matter if its on cool or heat, any ideas? Its a daikin ftxs71fvma
THE ONLT PARTS THATS COMMON WITH BOTH HEAT AND COOL IS THE TRANSFORMER AND THE EVAPORATOR FAN MOTOR.
Nov 27, 2009 | Cfm Daikin R410a Split System Air...
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Cfm Daikin R410a Split System Air Conditioner Logo
1,198 people viewed this question
Top Cfm Heating & Cooling Experts
Dan Webster
Dan Webster
David Payne
David Payne
Donni Steen
Are you a Cfm Heating and Cooling Expert? Answer questions, earn points and help others
