Question about GPS
Hi there. I have a falcon XR6 BA, 2004. When I arm the central locking via the wireless remote, the doors are all locking as normal. However, there are two doors which when the handles are lifted while the car is locked, disarms the locking system and gives access to the car. Not a good thing. How can I fix this myself, or is it a job for the proffessionals.
    President:
  • 1,561 Answers
This is electrical fault that you might not be able at all, infact, it not just an ordinary mechanic work, this needs a specialist in rewire of cars because this shows that the central lock mechanism is faulty and might need to be work on, so it is not what you can handle in other not to complicate issues.
I advice you get a rewire professional to help handle the problem and you could even change the central lock mechanism for safety and security purpose since the one there is already malfunctioning.
Take care.
Posted on May 26, 2010
My Falcon seems to take a while to start and I have to press the accelerator as well or it will stall, whats the deal?
My 2004 BA Falcon won't start. Apparently it's low - Fixya
www.fixya.com/cars/t12343045-2004_ba_falcon_start_apparently_s_low
Apr 8, 2012 - Apparently it's low on - Ford 2005 Falcon 4.0 question. ... Ba engine generally is strong, common fault is ecu, if hard starting when cold, pour hot water on computer and it ... If the headlights do not dim or go out, then the battery is likely ok..... Automatic 2004 BA Falcon stalls while driving ... Open Questions:.
My xr6 won't start. Comes up saying immobilized. - Fixya
www.fixya.com/.../t12430461-xr6_start_comes_up_saying_immobilized
Feb 6, 2012 - My xr6 won't start. ... Question about 2005 Ford Falcon 4.0 ... you will get airbag errors popping up for a few weeks then after a while it .... in a while it willstart and run for about 20 seconds, then it dies and won't start. ... Open Questions: ...You may NOT copy or distribute the content that appears on this site ...
Ford falcon sometimes won't start - Ford - Automotive - Whirlpool ...
forums.whirlpool.net.au > Automotive > Ford
WhirlpoolOct 26, 2010 - I have a EF Falcon that has an intermittent problem with starting. ... It might take a minute or 5 minutes or persistent retrying. ... Normally if you wiggle the T-Bar around it will then start. ... motor with a rebuilt unit, I had a remove starter on myalarm, and would use the remote start while using my jack-handle to ... Worst Car You Ever Owned
Jun 1, 2012
LPG conversion problems with stalling - Ford
Jan 16, 2012
More results from forums.whirlpool.net.au
2006 Ford Explorer Engine Stalls While Idling: 24 Complaints
www.carcomplaints.com/Ford/Explorer/.../engine_stalls_while_idling.sht...
Jan 27, 2016 | 2005 Ford Falcon 4.0
What grade oil for 2002 ford xr6 ?
BA Oil 10W-30 - Ford Forums - Mustang Forum, Ford Trucks, Ford ...
www.fordforums.com/f532/ba-oil-10w-30-a-88210/
Oct 31, 2004 - I'm using castrol fumula R synthetic 5/30, as this was recommended by... BA XR6 - December 2002 ~ Soon to disappear if Ford CRC can't fix it. Help what type of oil are you using in 302 windsors
Jul 4, 2004
Oils advice
Feb 26, 2004
BA recommended oil visc.
Feb 5, 2004
EF-XR6 Oil pressure Gauge Probs
Apr 23, 2003
More results from www.fordforums.com
Thread: which engine oil for BA DOHC motor? - Ford Australia Forums
www.fordaustraliaforums.com > ... > B Series Mechanical
Aug 29, 2007 - 14 posts - ‎10 authors
what oils are you guys using for your BA 6 cylinders? ... (I am only on 75000 km, so will stick to the Ford recommended 10W-30 for the time being) ... F250 cab , BA2 XR6Turbo engine , dash and firewall , GU Nissan Patrol ...
Best 15W-40 Engine Oil - Topic
forums.noria.com/eve/forums/a/tpc/f/616604995/m/361101242
Jan 01, 2016 | Ford Cars & Trucks
Change bulb 2004 ford falcon ba xr6
Remove the battery if it is RH side bulb then remove dust cover and you are at the rear of the bulb
Apr 30, 2014 | 2005 Ford Falcon
Ba ford xr6
it needs to be taken to the dealer
Oct 29, 2013 | 2005 Ford Falcon 4.0
BA Falcon XR6 Turbo ute central locking not working
We do not have this model in the USA so have no info on it. Sorry.
Apr 26, 2012 | Ford Falcon Cars & Trucks
I need a 1998 mazda 323 ba immobiliser bypass key or another solution to start my car. Can anyone help me?
I know this question is old but I recently encountered a similar problem with my 1995 323 BA and this may help someone else. Override the immobilizer by doing the following:
open the car via the drivers door
put the key in the ignition
turn the key to ACC
now turn the key to ON
repeat the last 2 steps X 12 quickly (ignore the indicators flashing and the central locking activating).
the dashboard should be lighting up as normal.
Now turn the key to START
Sep 26, 2011 | 1994 Mazda 323
BA Falcon 'door open' light is on, can't lock
Hi I have the same problem on my BA XT Falcon
Strangely it only happens after it's rained on my car (usually overnight) I then notice that the drivers lock is up and will not lock again until a nice sunny day comes and I leave all doors wide open for hours and hours!! Then all of a sudden once closing all doors normally the little dash door light turns off, and I can again lock the doors
Since it rained all last night here, guess what? It happened again!
So I've checked everywhere and cleaned and you name it, but nothing, I'm positive that when a warm sunny day comes again though, all will be ok.
Most annoying issue ever.
Where is this tiny bit of water that's causing this?
And which door?? Can I just disconnect one door at a time? I don't know it's driving me crazy!!!!
Jun 05, 2010 | 2005 Ford Futura
GPS Logo
76 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
