Question about Sony Walkman WM-FX277 Personal Cassette Player
HI everyone, I need your help. I have change the black rubber band in the walkman but now when i play the tape it doesn't produce any sound.....On the other hand when i switch on the radio it has sound......Why? Pls Help?
  • Sony Master
  • 17,129 Answers
The black rubber bank is the belt that drives your motor to turn the capstan to eventtually turn the cassette. Now check if the motor is turning the capstan, the larger wheel over which you had wound up the belt. If not check if any connections have been detached when you did the belt change. Within the mechansim there is a small spring leaf switch that activates the motor and the circuits. so check this out or if you can use a multimeter to trace the voltage to the motor and circuit. If this was working prior to your work then look carefully for a careless lapse. I hope you must have wound the belt in the right direction. Helpful? Good day
Posted on Jul 22, 2010
Frequency response
Fixya does not make purchase recommendations.
Jul 14, 2017 | Radio Communications
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
Cassette adapter for toyota harrier
sounds to me like your tape belt in the other motor has broke ,the drive for the tape deck has a rubber band putting it crudely and these belts are a special rubber ,it should be a easy repair but make sure you get the right size rubber band but they must be made for a tape deck and not one from office draw
Apr 27, 2012 | Lexus RX 330 Cars & Trucks
Playback Sony Professional Walkman
Sounds like the pinch roller isn't engaging. The pinch roller is a black rubber wheel that presses against a silver post (capstan) the tape is held between them. With the door open and no tape press play. The roller and capstan should touch. If it recently ate a tape there could be some tape on the capstan that also will cause it to run fast.
Feb 03, 2010 | Sony Audio Players & Recorders
My VHS tape is also stuck--tapping didn't help
does ur vcr have a idler wheel or gears (between both spindles?) if its an idler wheel, with rubber band it commonly can go bad. their a pain. unfortunately there may not be a replacemant part. if nopt, inspect the belt for cracks or glazing. it needs friction to spin the spindle to take up the tape being played. or if ejecting, to wind the tape back in the cassete. take off the cover of vcr and watch. if the right side wheel of tape is not turning while playing, theres ur problem. the tape is instead floating every whichway. another possibility could be a belt on the right spindle. if any bands need replacing, use an ordinary rubber band ,. should work just as good
Jul 31, 2009 | Televison & Video
FUNAI DVD/VCR COMBO
You need to replace all rubber bands inside the VHS.Vary difficult to find rubber band kit.If you use the TV in the heat, u must place a fan of some kind in the back blowing IN to cool the insides of TV. [AFTER U REPLACE rubber bands]
Jul 30, 2008 | Funai PY90VG DVD Player/VCR
WALKMAN NW-A3000
same problem with mine right now -- I find if you charge it fully then reset it multiple times between testing it then the sound works about 50% of the time. Havent found a real solution yet though.
Jan 13, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Black bands and skipping in playback
Thank You Guest, this this solution is helpful, I clean the head with alcohol and the problem is solved.
And thanks for FixYa for the technical support.
Apr 02, 2007 | Panasonic NV-GS11B Mini DV Digital...
Sony Walkman WM-FX277 Personal Cassette Player Logo
179 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
