Question about Sentry SE-RMC10 Remote Control
I have rca tv need code this is a big screen - Sentry SE-RMC10 Remote Control
Need Remote Controler Codes for Toshiba Remote for Toshiba Model TP61H60 a 1998 Big Scrren
Your Toshiba remote should have the necessary codes to control your Toshiba TV unless one is much older than the other.
If your RCA remote is programmable, you can use its "code search" feature to find an applicable code or codes. If a complete search of all codes stored in your RCA remote fails to find a code, you may have to try another programmable remote or simply wait until the replacement Toshiba remote arrives.
Sep 25, 2014 | Televison & Video
I need a new screen protector for my older RCA big screen TV
I have a screen protector from a 1998 RCA older model big box style tv
Mar 15, 2010 | RCA P56930BL 56" Rear Projection...
Need code for phillips big screen lost manual for jumbo remote
Code 002 for Philips TV Code 003 for Philips TV Code 004 for Philips TV Code 008 for Philips TV Code 012 for Philips TV Code 019 for Philips TV Code 062 for Philips TV Code 068 for Philips TV Code 069 for Philips TV Code 075 for Philips TV Code 076 for Philips TV Code 086 for Philips TV Code 087 for Philips TV Code 088 for Philips TV Code 130 for Philips TV Code 132 for Philips TV Code 134 for Philips TV Code 167 for Philips TV Code 183 for Philips TV Code 196 for Philips TV
Jul 12, 2009 | RCA RCU600M Remote Control
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
.Need TV code
Here are the RCA TV codes ---1000/1003/1004/1005/1009/1054/1055/1082/1096/1098/1099/1100/1101/1102/1103/1129/1179/
1181/1188/1190/1203/1212/1233/1240/1252--The codes are out of a RCA universal remote booklet
hope it helps good luck
Jan 02, 2009 | Proview PA-32JK1A 32 in. LCD Television
RCA big screen tv
you got high voltage going somewhere that can be cuased by a blown fuse these rca big screen tv's have up 6 fuses one of them may be blow that needs replacing
Jul 03, 2008 | Televison & Video
Codes
I have a dynatron DYN100R that I cannot find the codes for, for an RCA TV
Apr 20, 2008 | Televison & Video
Arcing noise in big screen tv 1996 rca
Probable bad HV block Part # 205064
Possible bad CRT = disconnect HV leads one at a time from
HV block until arcing goes away
Please rate this solution..........
Nov 14, 2007 | Televison & Video
Sentry SE-RMC10 Remote Control Logo
154 people viewed this question
Top Sentry Televison & Video Experts
Ed Mac
Christopher Stearns
Computer Repairing
Computer Repairing
Are you a Sentry Televison and Video Expert? Answer questions, earn points and help others
