Question about Maytag Dishwashers
Smell like hot tar fues when in use
Why did maytag wrap thick tar paper around thier steam dishwashers didnt they know better when in use the tar emits bad smell like fresh tar being applied before pavingn roads it also burns one eyes if i cant fix this problem will have to return to sears please advise me like dishwasher otherwise
SOURCE: cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Posted on Jan 06, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
  • 18 Answers
SOURCE: dishwasher had a burning smell and smoke was coming out
If the smoke was coming from inside the dishwasher... A common problem is a plastic item , utensil etc has fallen down onto the heating element. During the drying cycle this could possibly melt the plastic and generate some smoke.
Posted on Jan 04, 2009
MNfisherman
  • 11896 Answers
SOURCE: Maytag Quiet Series 300 dishwasher, dishes come out dirty
A water softner will not make the dishes any cleaner, it just makes it so they don't have water spots on them.
If the dishes are dirty, it is most likely that the nozzles (holes) in arms may be plugged.
Also check to make sure you are getting plenty of water to dishwasher. Make sure all water valves are full turned open.
If the control panel does not work all the time, it is very likely you have either a shorted wire, or a fualty main board which is very common in newer machines.
Posted on Jun 01, 2009
Hugh fulton
  • 62 Answers
SOURCE: bad smell from my samsung dmr77lhs dishwasher what to do?
Put about three or four drops of eucalypt oil into your dishwasher and put it on a wash cycle - you don't need to use the drying cycle. Then is should smell beautifully. It's probably just the newness of the machine with seals and parts all giving off the smell. If that doesn't work contact the dealer and get them to find out what it is. After all you paid good money for it.
Good Luck
Posted on Sep 13, 2009
Pipes will not pull apart
depending on the joint but holding it over the steam of a boiling kettle or wrapping a tea towel around the joint and pour boiling water on it, allow to sit 2 minutes then separate. Be careful and wear thick gloves
Jan 11, 2011 | Vacuums
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Ink smudging off paper
It means that the fuser is not hot enough to bond the toner to the paper. You should open the rear door and see if a paper has wrapped around the fuser roller, as when the temp is actually too cool it will shut down the printer. Photo paper is also too thick to be used in this printer and you should only be using standard bond paper.
Feb 22, 2010 | Minolta magicolor 2400W Laser Printer
Cigarette smell in cars
professional cleaning sounds like your best deal unfortunatley with what you are describing it will cost @$400 to $500 to clean. If you decided to quit smoking it might take you about month and a half of your cig money to pay for the cleaning
Sep 02, 2009 | 1999 Chevrolet Cavalier
Where do I put card stock paper in to copy?
Check your operators manual, it well tell how to install, also you mite need to know how thick the paper is, see the wrapping paper that raped the paper. like 20lbs or 75g/ms grams meter squared. Stock paper mite be thicker 26lbs 93g/ms like i said check the outer wrapping, Try the bypass most likely,
Aug 16, 2009 | Canon Office Equipment & Supplies
My Maytag Neptune TL has a moldy smell that I can't seem to get rid of. I've used a steam cleaner to blast away mold I've found around the rim and other parts I can reach, and I've run cycles of just hot...
Take off the round agitators one at a time, by popping off the center cap and use a hex driver to remove the screw. Tilt out aggitator, and clean back of agitator, hyousing and gear box of the moldy/mildew build up..its kinda gross. That is where the stink comes from.
Jul 28, 2009 | Maytag Neptune FAV6800AW Top Load Washer
I have a 1E error code. Water supply is good to the machine. Not sure how to get to the filters. Don't want to break anything.
Ok found the filter in the front of machine, lower left hand corner. It was clean. Proceeded to remove front panel. But first turn of the power and I also turned of the water. Now I found that the wires from the wiring harness had imbedded themselves in the sound profing material. Its like a black thick tar. I guess during the drying cycle the tar heats up and the wires settle into the goo. As the door is opened and closed the wires are put under stress because they are now one with the door. I found a blue wire had broken. I soldered the wire and taped it. I also put waxed paper behind the wires to keep them from hooking up to the tar again. I will check that fix after a couple of months to see how the paper is faring. The machine works perfectly once again.
Jan 08, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
42 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
