Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Problem getting belt around motor shaft... Eureka The BOSS
I have removed cover and can put belt over brush roller just can not find clearance to put belt over motor shaft???
  • djohn265 Apr 09, 2008
    I have done that but it appears that the motor shaft is connected to the plastic. The tension does not seem to change whether it is locked or not. I am wondering if I should try to remove the top cover?
Make sure the vacuum is in the upright (locked position) - when you lower the handle, this puts tention on the belt. If it is in the upright and locked position, there is plenty of clearance (unless you have the wrong belt.
Posted on Apr 08, 2008
How do I get to the belt on my dirt devil
On the bottom of the dirt devil have to remove cover plate with screws and replace belt on motor
Apr 20, 2015 | Dirt Devil Featherlite Bagless Vacuum...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
How to replace belt on a eureka boss vacuum
if you look on the base plate you should see a diagram of how to do it,but if yours don't have a diagram then remove the screws from the base plate it should be three or four they have arrows next to them. take the base plate off and remove the brush roller and the old belt off being sure to put on bear floor then put the belt on the drive shaft put the brushroller in left side first
Jun 28, 2010 | Eureka 4870SZX BOSS SMARTVAC PET LOVER...
My Eureka The boss Smartvac Model #4870 roller brush won't turn even on the highest setting and the belt smells hot. we took the belt off. How can you tell if it needs replaced?
Just by what you explained I can tell that it needs to be replaced. The belt doesn't have to be broken to need replacing, if it is stretched and worn then it will slip on the motor shaft and not turn the brush roll and get hot. Here is a link to the belts you need and the manual which has instructions:
Bissell 4870 Belts
Owner's Guide (3,666K download)
Dec 11, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
I have a Eureka Altima and not sure how to change the belt?
1) Use handle release to lower handle
flat onto floor
2) Remove 2 screws from the front side of
brush roll cover
3) Lift and remove brush roll cover .
4) Remove brush roll and belt. Thread
new belt around motor shaft and
brush roll
5) Insert left end of brush roll first. Make
sure square on brush roll cap is in
place. Pull right side of brush roll to
stretch belt. Secure right end cap into
base.
6) Rotate brush roll 2 turns to center belt.
7) Replace brush roll cover
8) Replace 2 screws
And you can get the maual here.
http://www.eureka.com/service/manuals/80244.pdf
Good luck
Sep 27, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
I want to replace the belt on an upright eureka vacuum model 4481, any ideas?
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Jun 08, 2009 | Eureka Whirlwind 4481 Upright Vacuum
Can not change belt
some of the eurekas ha screws on the top of the base to remove the cover.others have the screws on the bottom.if they are on the bottom there will be 5 screws1 on each en of the roller in front and 2 on each end of the roller behind the brush and 1on the rear of the bottom plate where yo can see where the belt guide is.make sure you clean the old rubber off the motor shaft or your new belt won't last
Apr 23, 2009 | Vacuums
Changing the belt
Have you pulled the roller out? Once you take the bottom plate off, the roller should slide out of its slot. Then you should easily be able to access the motor shaft.
May 03, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Belts
There should be 2 or 3 screws on the top cover, then you can remove the cover and the brush roll and belt are in the open. Put the belt around the motor shaft, then around the brush roll and stretch it until it goes into the place for the brush roll. While out, check the brush roll ends, make sure they turn freely, if not, then replace it.
Mar 11, 2008 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
116 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
