Question about Xerox Computers & Internet
Reformat hard drive
Remove any files from hard drive
  • 185 Answers
How to format your hard drive and re install your operating system.
in order for you to do this you have to (before you format)
1. make sure that you have your recovery cd's or a cd/DVD with your operating system (windows or Mac)
2. try to back up all your information to an external Hard drive or DVD's depends on how much usable information you may have.
3. try to handpic your files to back up because if you do an auto back up you will end up with the same problem again.
-- to do a back up copy all your needed files to an empty folder and then burn them to DVD's or copy to an ext. HD.
4. after you do that (if you have your recovery cd's) insert #1 and restart your computer it will tell you to press any key to start from cd do that and follow directions.
5. when the program shows your partitions go ahead and delete them all, you need to end up with one
6. when you see just one partition go ahead and click continue and it will install your new operating system
7. if you have more than 1 cd it will ask you to insert the next one and so on.
8 after it finishes installing, get the cd out and run the setup process like if you've got a brand new computer, type the information and keep clicking next.
9. at one point you would be on the windows screen and that is it you have a brand new operating system.
Note: take in consideration that when you follow this process, you
erase EVERYTHING from the system including files and programs so after you do this you are going to have to re-install all your programs and copy your docs. back to the pc.
**** If you don't have the discs
check under start-(all) programs - start up- recovery- disk creation.
that (if you have it) will help you to create your recovery disks try to use 2 dvd's if posible if not you may have to get a windows cd to re- install and install drivers and apps.
if it works for you don't forget to rate me
thx
Posted on May 26, 2010
The files in my 500gb hard **** turn to short cut
scan your usb because your files has infected with viruses, go to start in your PC look for cmd command type cmd you will drive D: change to your drive just type E: or F: and type dir to see all files. or reformat to remove virus save your files to other drive.
Sep 17, 2011 | Samsung AA-HE0P500 500 GB - External -...
Do i need a new hard drive if my old one say (corrupted profile all the time) ?? plz help !!
No, just remove the hard drive and connect it to any computer to reformat the hard disk drive. It will be okay after reformating. But back up your files, all the files will be delete when reformating the disk
Dec 23, 2010 | Microsoft Xbox 360 Hard Drive (120GB)
My Dell desktop computer will not boot and it is too old to spend money on repairs. However, I would like to be able to get the files off my hard drive. If I buy a kit and turn the internal hard drive...
Nope. you cannot access your files. even if you use a external hard dive to access the files.
i suggest you install windows 7 in your computer but do not reformat the hard disk . in that way your files will still be saved in your harddrive.
Once you have access to your files i suggest you save them in a flash drive or external hard drive if you have one. then reformat your computer and install a windows xp.
here is a tutorial on how to install windows 7 without reformatting your harddrive.
Goodluck. If you have any success using my solution please give me updates.. Thanks
Nov 09, 2010 | Dell Dimension E521 (D10E16) PC Desktop
Unknown device after fall
Definately try another PC. If it will read, back up your files and try a reformat. Drive may have mechanical issues though as they are not very stable while the platters are spinning.
Mar 14, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Reformatted the external hard drive and lost files
Unfortunately, there's no way to retrieve any PC files. Once you reformat your external HD, everything would be erased.
Thank you!
Jan 04, 2010 | Computers & Internet
I have a corrupted file on my ps3 and it trys to repair it self after 30 seconds.it goes right back to the same screen. HELP!!!
Your problem may be more widespread than just that one file. The file system on your hard drive may be corrupt. You can try to reformat the entire hard drive in an attempt to remove all the errors in the PS3 data, or you can buy a new hard drive. You may have to replace the hard drive if the hard drive is failing, and therefore not reading or writing data properly.
To reformat the drive, in the PS3 menu:
NOTE: This will erase everything you saved on the hard drive.
1) Go to the Settings menu, then select System Settings.
2) Select Format Utility, then select Format Hard Disk.
3) Select Quick Format
To replace the Hard Drive, buy any 2.5 inch notebook hard drive that has a serial ATA connection. Then remove the old hard drive from the left side of the PS3 and install the new hard drive.
After installing the new Hard Drive you will need to format the drive. When you turn on the PS3, you will see onscreen instructions to help you with this.
Nov 24, 2009 | Sony PlayStation® 3 (60 GB) Console
Not saving games lost files seems to be corrupted
You can try to reformat the entire hard drive, or you can buy a new hard drive.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
Verbatim 8G drive removed without clicking device removal. Now the Verbatim drive does not show Disk Name or Directory name, and OS asks to reformat. How can I restore to recover drive and files without...
thats the best sulotion reformat the drive and recover all your files by power data recovery software download this software give me your email. i will send you a copy for this.
Nov 10, 2009 | Verbatim STORE-N-GO (95312) 8 GB Hard...
My precious files...
If you have not written anything to the disk since you accidentally formatted it I can recover all your files for you. If you wrote any files to it some of the files will be ruined. I have FBI forensic software that can do what you need and more. Rate this fixya and post an e-mail address and I will get the software to you.
George
Jul 25, 2008 | Computers & Internet
Computers & Internet Logo
333 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
