Question about Garden
I have a B & S Quantum 6.0 engine and it won't start at all but if I hold the carbi wide ope it will. Whats going on
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 27, 2010
Brand new 25cc. baumr au sx25 chain saw wont start.has spark , fresh fuel ,even tried ( start you b. ). Not even a kick. I have tried on about 6 or 7 different days with no success ?
take it back in for a warranty check as it is brand new
if it has a primer bulb then press it sparingly as the will flood the carby very easily
pull the plug , hold the throttle wide open and pull the cord a dozen times to remove excess fuel from the crankcase
Apr 28, 2016 | Garden
John Deere. Why does it start but then shut off?
problem in the carby
could be fuel supply or dirt/ watre around the main jet
Nov 10, 2015 | Garden
Quantum xte power washer
carby full of oil due to possible roll over of machine, remove carby bowl and clean with brake cleaner or similar. re assemble and try, disconect oil pressure switch while testing to eliminate that issue, usually connected to off switch.
Apr 02, 2014 | Briggs & Stratton Garden
Why won't my scooter start/
you have a fuel blockage problem. The fuel gets into the carby slowly and allows you to start but the rev increase is an indication that the air/ fuel ration is going lean and then the motor stops. The same as if you turn off the tap and let the engine run until it stops. It won't start again until there is sufficient fuel in the carby bowl to get to the main jet.
Jul 27, 2013 | 2008 Tank Sports Urban 50
Will not idle
Reconnect the governor rod back on to the carby throttle butterfly correctly. When stopped the lever will hold the throttle wide open and as it starts the lever pushes /pulls the throttle closed to the idle stop screw
May 31, 2013 | 5.5 HP GX160 Engine
I have a yzf R15 got drowned in water .cleaned most of the motor and cleaning carby now any other tips on why it won't start would be very helpful .thanks....
check ht leads and caps. all connections for corrosion, is battery ok, are coil wirings ok, whats the air filter like,
Feb 19, 2013 | Motorcycles
Quantum audio qca4000d mono block amp 4000 watts cosmic series. when car is turned off amp works fine. when I start the car protection light kicks on. Whats wrong
How do u connect a quantiam audeo 4000 monoblock wats with 15s q powers I tryed it but they do not sound da way I though they were going to sound let me no som thing thanks?
Nov 09, 2011 | Quantum Car Audio & Video
Pressure washer (gas)starts then immediately stops? not getting gas?
Check oil level as some are fitted with oil alert, if its been sitting it will have blocked jets. if its a briggs with a Quantum the bolt thats holds the caby bowl on has the main jet built in it. remove the bolt and clean the jet 2 holes on the side feeding the 1 from the top. If its a honda or a Chonda remove the carby and jets and clean.
Jun 30, 2010 | Garden
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
