Question about Compaq fs740 17" CRT Monitor
Monitor screen problem
I have a compaq fs740. While I'm working on the computer the entire screen will turn entirely orange or blue with slightly slanted lines. I can slightly see my information stil in the background. I have to wait for the screen to turn back to normal which may take a few minutes or a few hours.
    Guru:
  • 1,342 Answers
Check your cables. Make sure they are secure.
Posted on Apr 07, 2008
Compaq monitor FS740 is turned off after some time
Step 1:
Check your screen saver setting.
Step 2:
check your monitor setting to always in active mode.
Jan 10, 2013 | Compaq FS740 Color Monitor
Inherited Compaq FS740 but after hooking up monitor will show green for a short time and then color is yellow? Is it dead? Has set up for a while
Check the pins on the cables. Single color presentation but clear picture indicates the pin for a particular color is borken on teh cable. Remember Red Green and Blue are mixed to make other colors. If you have predominantly one color then its due to cable not haveing all pins inserted properly or damaged.
Jun 28, 2010 | Compaq fs740 17" CRT Monitor
WhenI turn my monitor on, a screen appears saying VGA input - no signal & DVI input - no siganl & then it goes to sleep
Do you have multiple Video cards installed in your computer?
Check the monitor on another computer to verify the Monitor works and so does the cable.
If Monitor works, cable works, and you have 1 video output from your computer, then your Video card is probably no good.
Jan 26, 2010 | Compaq fs740 17" CRT Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Compaq FS740
try pressing escape. or press f8 when your computer starts up and then press factory restore
Jun 22, 2008 | Compaq fs740 17" CRT Monitor
MONITOR SCREEN KEEPS BLANKING OUT WITH A ORANGE COLOR OR BLUE COLOR
It is one coulour missing and it can b mostly due to CRT socket loose or some dry solder in CRT {RGB) path..
Chck out...
This is a technical freak from INDIA!
Apr 07, 2008 | Compaq fs740 17" CRT Monitor
Monitor is tilted forward and wont tip back
it will tilt back, just make sure the stand is in the forward most position and not turned and hold the screen at top and push while at the same time pull at the bottom, it will be quite stiff.
Sep 23, 2007 | Compaq fs740 17" CRT Monitor
Compaq monitor
OK your monitor is failing in the Horizontal circuitry.... OR the PSU is failing to supply the correct Voltages. Either way it is probably going to fail completely soon. With monitors so cheap now, here in NZ they are about NZ$20.00 - $50.00, repair isn't adviseable to do so, it would make more sense to put the Repair monies into a NEW screen... maybe time for an LCD?
Jul 22, 2007 | Compaq fs740 17" CRT Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Concave screen problem also
OK All these Compaq's have a Power Supply problem, or a Horizontal Voltage problem.. meaning they are on the way out. The SMPSU's in these units often fail along with the Horizontal Drive Circuitry. I think it is time for a new one? Repair of such a unint would barely be "Ecconomical" IMHO.
Jun 08, 2006 | Compaq fs740 17" CRT Monitor
Compaq fs740 17" CRT Monitor Logo
113 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
