Question about Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive
Boot device hello sir, it is showing a error msg::"please select a proper boot device and press any key" im frequently facing this problem my motherboard and all other components are working fine can u plz say the warranty period of hdd.............
  • 180 Answers
Your hard disk has upto 3 years warranty from the day of purchase
Posted on May 26, 2010
Hello, My laptop shows the following message when I turn it on- Realtek PCIe FE Family controller Series v1.19(08/10/09) PXE-EGI-Media test failure,check cable PXE-MOF-Exiting PXE ROM Reboot an
It can't locate a working boot disc. Most likely lost communications with hard drive. Look in BIOS again to see it recognizes the drive. If not try re-seating / reconnecting drive.
Feb 16, 2013 | Dell Inspiron N5010 Black
Booting up new motherboard
You need to re enter system setup Press Del and change boot device order to floppy, CD/DVD and Hard Disk
Worldvet
Jul 05, 2008 | ASUS P5PE-VM Motherboard
Hello sir i have installed the drives and as per the instruction but its been not working properly in my system it when ever we click that icon it display by running and shows...
what error message is showing???? spell it out
the drivers might be installed for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
if you need more help with this post a reply
hope it helps
Sep 21, 2011 | Computers & Internet
Sir good day for you.. ah i have a problem bout my cpu. i lost my driver so that i cant format my cpu now coz i dont have driver and then i try to download but always error i get.. so can you help me to...
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you must go back and change the first boot device to your hard drive
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
or if you are using a USB
insert your usb drive
click start right click on my computer select open you should see your USB drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
May 16, 2011 | Foxconn 45CMX socket LGA775 motherboard...
There is a PC made by myself ,it is included MSI482M-IL. Now it is W2K. I want to install W-XP. I tried install that,but I can't. Becuase always PC set up W2K. I can't boot control in this BIOS. How...
go to bios setting first, then at boot device select boot from cd at first, then press f10 to save then enter, pc will reboot, insert winxp cd then press any key at "press any key to boot from cd" appear then follow instruction that shown after that
i hope this helpfull, please rate very helpfull if you think this helpfull
thanks for using fixya
Jan 22, 2011 | MSI RS482M-IL (7145060RS482MIL)...
Not booting
There may be many issues, lets start with the most common one,
When the notebook is starting up press the button it states to "Enter Setup" (I mean BIOS). (May be F8 or DEL) {differnt for diffent machines}.
When entered, there find the Boot sequence under the boot ot boot order menu (This may also be different for diferent machines).
When found, there set the "First boot device to be "CD/DVD" not the IDE/HD/Hard Drive.
Not put the CD, it will boot hopefully.
If the problem prevails, or there is already CD as the 1st boot device.
Then don't hesitate to contact again, and also state the error you are getting when trying to boot.
It this was helpful, kindly do rate!
Always here to help!
Regards.
Jul 18, 2009 | Dell Latitude D600 Notebook
Reboot and select proper boot device
Hi, ull need to check the boot device priority in ur BIOS which is accessable usualy by pressing the delete key at the start of the boot process. If everthing is correct there and yet it doesnt boot from ur hard disk, try changing it to boot from cd and check if it boots. If it does then i think either your hard disk is corrupted or your OS.
Jul 08, 2009 | EliteGroup ECS 755-A2 Motherboard
A bootable device has not been detected
A bootable device has not been detected.
Please refer to the product guide.
Jun 15, 2009 | Intel D946GZIS Motherboard
Non allocatable error message on a cd made under winME trying to read in xp help please
When i turn on of my pc. then bios screen msg reboot and select proper boot device or insert boot media in the selected boot device. How to solve of this problem. pls .............solve tips for give me.
Apr 09, 2009 | Dell Computers & Internet
Open Questions:
Samsung 250GB HD250HJ SATA II 300 7200rpm 8MB cache HDD Hard Disk Drive oem HD250HJ 250 GB SATA Hard Drive Logo
195 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
