Question about Hotpoint HSS25GFP Side by Side Refrigerator
The freezer keeps freesing up and stops the air
The freezer keeps freesing up and stops the air flow into the refrigerator section therefore everything inside the fridge gets spoiled. we take the back off inside the freezer and it is all froze up
  • Hotpoint Master
  • 1,606 Answers
Excuse me , but your fan works off 6-9 volts DC so do not try 120 volt cord . Your refrig has no defrost timer . It works off thermistors and a main control board .
Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater WR51X10055 . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off at selected temp.
Posted on May 27, 2010
    President:
  • 1,796 Answers
Hi!!
Check fridge temp. control.
Check fan in freezer (should come on if door is kept open a couple of minutes.) if fan does't come on,
or if weak (should come on strong), unplugg the unit and take back cover off, (should be 4 screws), test fan applying 110v AC to it, if defective, replace. If fan OK, check for iced up evaporator, if so, defrost using a heat gun or hair dryer, make sure air duct to fridge is clear of ice..
Adjust temp. settings according to manufacturer suggestion (wait 24 hrs. before adjustments)
If it it freezes again, your freezer defrost timer may be defective. Replace it.
Don"t forget to rate this post. Good Luck
Posted on May 26, 2010
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
Apr 25, 2011 | Haier HRT02WNCBB (17 cu ft) Compact...
Freezer not sufficiently cold.
I would sugest here that the freezer coil has frozen over blocking the air flow to the freezer.
The refrigerator section is still probably ok because the could air will drop down the air duct keeping this section clear.
Try manually defrosting the freezer and see if that makes a difference.
If it does you will need a technician to sort out the automatic defrost cycle for you
Apr 04, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Freezer will not keep foods frozen fridge will not keeep temp.
Sounds like a main control board problem keeping the freezer fan from working . If no air flow to the top of the freezer , the icemaker will stop working and the ice will begin to melt ( leaking from freezer ) . The coils will start to freeze up due to no air flow across them . If continued for a period of time , the cold air could return thru the return vent located in the bottom of the ref/freezer section and freeze the water tank in the refrig section , causing the no water thru dispensor .
Jul 11, 2009 | Hotpoint HSS25GFP Side by Side...
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Have side by side refrigerator (approx. 10 yrs old). Fridge no longer keeps food cold enough even at highest setting and freezer isn't as cold either.
Your refrigerator needs to be turned off and aompletely defrosted. Overnight if possible. You have a large amount of ice built up on the freezer coil that is blocking air flow.
Most refrigerator sections are only cooled by air flow from the fan in the freezer section.
Thaw it and clean it out real good and you should be back in business.
Jun 10, 2008 | GE Refrigerators
FRIDGE NOT WORKING
Most side by side and other models of refrigerator freezer combinations are of one basic design. The freezer section does the cooling for both compartments. The refrigerator section gets it cold air from the freezer compartment. Therefore check for frost on the back wall of the freezer compartment. If frost is present there you have a defrost problem and it is cutting off the air that cools the refrigerator section.
I think this problem may already be resolved in some manor because of the date of post. Posts should expire after an unreasonable time period.
Mar 19, 2008 | Smeg FA561X Side by Side Refrigerator
Maytag Refrigerator
You don't have enough cold air circulating over into the refrigerator section. This is usually controlled by an adjustable "flap" or door which is hooked to a conrol knob. When you rotate the knob you change the size of the opening which controls the air flow to the refrigerator secton. Also you may may have something blocking this air flow -- --- - like a wrapper from an ice cream bar, etc. Try to find the opening between the freezer and refrigerator sections and look for an obstruction.
Stargazer
Mar 19, 2008 | Refrigerators
Both the Freezer and the Refridgerator quit working...
Do you have ice build up on the back wall in the freezer? If so you have whats called a defrost problem. (can be timmer, adc, heating element or thermostat)... All cold air in you fridge side come from the freezer, therefore if you have ice build up behind back wall in freezer it is blocking air flow....
Dec 21, 2007 | Maytag MTF2156GEQ Top Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
373 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
