Question about NEC PlasmaSync PX-50XM4A 50 in. HDTV-Ready Television
No volume on my plasma tv it was working an hour ago i turned on everything manually then I had no sound. I dont know wht to do can anyone help?
Hope to turn on Sylvania 6413 TC 13" Tv using circuit board
Where can I download an operator's or repair manual for an ...
www.fixya.com/.../t26005148-anyone_knopw_dowload_operators_or_r...
2 hours ago - how do you program a olevia 542-b11 with the tv buttons ,I do not have a remote ... Hope to turn on Sylvania 6413 TC 13" Tv using circuit board.
I need help with my Sylvania TV - ecoustics.com
www.ecoustics.com > Forum > Home Video Forum > TV Forum
Dec 10, 2004 - Anyone know how to set the mode to video without using a remote. ... Where can I obtain a schematic for my Sylvania 13" TV/VCR combo - Model SSC132? I can see no physical damage to parts on the circuit board, but need a service manual to ... The unit will not turn on when the "on" button is pressed.Missing: 6413 ‎tc
How to Repair Your Plasma TV With Blinking LED - YouTube
? 2:52
https://www.youtube.com/watch?v=Y7b_nTaZYcU
Dec 13, 2009 - Uploaded by The Dollar Guy
How to Repair Your Plasma TV With Blinking LED ... TV has both the Samsung screen AND the matching ...
Dec 12, 2015 | Sylvania Televison & Video
Zenith Z42PX2D Plasma tv
Something short circuit with its circuit board. you must have through knowledge in electronics, and work experience to do repair work to this Plasma TV. As you know, plasma TVs are the latest technology devices, and a mere knowledge in electronics will not help. It will be best to get this set repaired by any experienced service technician or by the authorized service center for Zenith at your town. [Short circuit protection circuit energized, and latched the relay, not to supply voltage to damaged circuit board is the problem] The click sound you heard was the latch sound of the protection relay.
Aug 14, 2012 | Zenith Televison & Video
I have an Samsung PS42C451 Plasma 42" TV. I have had it for approximately 10 months. I turned it on today and I have no picture but I still have sound. This has never happened before. I can't even see...
i have a samsung plasma tv ps42c451 bought xmas time about two months ago it decided that it was not going to give me a guide anymore all it does is says no information for everything .
Mar 08, 2011 | Samsung PS42P2S 42 in. Plasma Television
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
Toshiba 50HP66 and HDMI problem
hi the best thing to do is call toshiba and let them know your problem
Jan 10, 2009 | Toshiba 50HP66 50 in. Plasma Television
you might try checking the sap (secondary audio programming) option in your tv if it has one make sure it is turned off. if it is off or does not have that option you will most likely have to take it to a repair shop. i would not try to fix it my self as you will do more harm than good.
Dec 09, 2008 | Insignia IS 20" TV040919 TV
Daewoo DSP4210GM 42 in. EDTV Ready Plasma TV
what way did you set the tv in the transport vehicle. something has been knocked loose inside or the videomask has been damaged?
May 14, 2008 | Daewoo DSP4210GM 42 in. Plasma Television
Dell 32 inch LCD Tv volume and menue problems
We also have a 32" LCD Dell flat screen tv #W3201C that has no sound. It's about 2/12 yrs old. One speaker started having a problem and we disconnected it. That was a couple weeks ago, now there is no sound at all. Dell should not be let off the hook so easily. Obviously there is a problem with the tv and it should be Dell's responsibility to make it right. Does anyone know if a class action suit has been initiated?
Mar 08, 2008 | Dell W3201C 32 in. LCD Television
Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Dec 24, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
50in Plasma 50PB6
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Oct 29, 2007 | LG 50PX5D 50 in. Plasma HDTV
NEC PlasmaSync PX-50XM4A 50 in. HDTV-Ready Television Logo
59 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
