Question about LG BG8000ER Air Conditioner
Ac 1.5 ton
Symbol to Describe 1.5 Ton AC Unit on construction drawing
  • 8,197 Answers
It would be a snowflake.
The link below is a picture of one:
http://www.symbols.com/encyclopedia/09/0…
http://images.google.com/imgres?imgurl=h…
http://www.google.com/search?hl=en&clien…
It does not mater the size of the unit.
Posted on May 26, 2010
    President:
  • 1,796 Answers
Hi!!
Air Conditioner are measured by its cooling capacity in British Thermal Units (BTU's) One ton compressor provides 12,000 BTU's. 1.5 Ton. compressor provides 18,000 BTU's. This info. can be found in the compressor's identification plaque.
Don't forget to rate this post.
I want to know tonage of ac
12,000 but/ton. If the 101 in your model is their tonnage (101÷12=8.4. its a 8 1/2 ton (5 ton and a 3 1/2 ton combined). That's probably it or very close. I could not look it up cause I don't know the maker of the unit.
Jun 25, 2015 | Mitsubishi Heating & Cooling
How much load of two ton Ac
30 Amp X 2 would seem to be a 60 amp draw MAX, easily handled on an individual 30 amp circuit, providing they were not running non - stop. I would not run 2 AC's on any one home circuit. One 2 ton unit requires a 30 amp breaker for individual use.
Jun 03, 2014 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
How to tell the size of my ac unit?\
thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Jun 21, 2009 | Weather King Heating & Cooling
What wire size do I run for a 3 1/2 ton AC unit?
it depends on the distance from main power source # 8 if more than 40 feet look at starting amps then google a wire sizing voltage droop chart
May 08, 2009 | Heating & Cooling
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
LG BG8000ER Air Conditioner Logo
215 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
